Ok... this is the 74 orig 318 block with kb pistons, 280 cam, late magnum heads upgrade, and mp single plane intake manifold (all the recipe taken from article "the little mopar that could", carcraft magazine)
Everything was assembled to specs, then just little trouble with the timing on the initial start and then started, after a few seconds a "shower" of milkshake started to come out from all around the oil filter... we turned of the engine, and checked oil dipstick and came out also with the oil and water/coolant mixed-up.
more info:
1) combustion did not fail (we turned off the engine) so water did not got into the cylinders
2) Took the intake out and noticed that it only uses the front square ports for water passage, so NO ports on the rear (this is where I suspect the water got into the valley but it did not looked evident) also the bottom of the intake (inside) was sprayed with water/oil.
3) Took both cylinder heads out.. everything looked normal but we noticed that the gasket does not have a water hole for the bigger front of block to head.. this seems to be normal because every gasket for small blocks we looked at seems to look the same way.
4) Removed the water pump, looked normal, no cracks on the housing and was well sealed, water passages thru timing chain housing looked normal, no cracks or holes.
5) Ran some air through block's water passages and they were still filled with clean water/coolant, this means no oil in the water sytem.. only water in the oil system.
6) The Valve cover insides and rockers were sprayed with water/oil drops.
The most courious thing is the huge ammount of water that managed to get into the oil in such a small period of time, so much that we believe that this caused so much pressure to be built inside and caused the shower thru the oil filter.
At this time we are clueless, the intake into the valley theory is the stongest but not 100% sure, also, although there's enough information that this magnum upgd. is supposed to be straight forwar,d we now also feel unsecure about something being wrong with the heads and or the relation to the block...
Any ideas?, Is this just a case of over/under torque or bad seal or is there the posibility of too much pressure in the water system?? due to what?...
Plase Help... any comment or experience is welcome
Excuse the long explanation!
