Author Topic: Wheel question- Do Ford wheels fit?  (Read 746 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: March 07, 2009 - 09:06:57 AM »
Quick question-
I saw another member on the site put the 17" Bullitt wheels on his car. I dig the look, and I can pick up a set for a reasonable price.
Will the 17"x9" Bullitt wheels fit?
Thanks!
Dan
Offline 73Chally
Re: Wheel question- Do Ford wheels fit?
« Reply #1 on: March 07, 2009 - 09:46:52 AM »
Bolt pattern is the same, but the backspacing (offset) is radially different, and requires a spacer.  It has been done before, but does require some work.  I believe there are also potential issues with aftermarket disc brake setups if you are using them.
« Reply #2 on: March 07, 2009 - 09:47:25 AM »
you need a 1+" wheel spacer/adapter to get the backspace correct...pre 05's work better
Offline DMZ73
« Reply #3 on: March 07, 2009 - 11:27:34 PM »
Thanks!
I'll remember that.
Best,
Dan
Offline Justins72
« Reply #4 on: March 09, 2009 - 11:06:45 AM »
i need the find the place but where i ordered mine they have a 17x8 with a 4.5 backspace wich fits perfect without any type of spacer unless you only want to go with a 17x9.
