Author Topic: Doug's Headers for Big Blocks  (Read 9740 times)
nivvy
Re: Doug's Headers for Big Blocks
« Reply #15 on: March 11, 2009 - 05:53:33 PM »
danas are the ultimate..... stock for stock a 8 3/4 is stronger than a 9".. the 8 3/4 will last you on the street fine.....
nivvy
« Reply #16 on: March 11, 2009 - 05:56:06 PM »
nice oil setup... is there a girdle on the bottom of there? I dont see one.......  :working:
looks good though.....  :burnout:
« Reply #17 on: March 11, 2009 - 06:35:53 PM »
Matt,
  It looks great!!   :ylsuper:
What size carb are you putting on top of it?
« Last Edit: March 12, 2009 - 04:51:49 AM by MEK-Dangerfield »
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #18 on: March 11, 2009 - 09:31:33 PM »
OK,
I got some pics of the new headers. Can you say "Kid in a Candy Store". It's like Christmas in March. My wife actually made me go out and help the UPS man!! The headers appear to be top quality. Haven't tried a dry fit-up yet, but this is how they look!! I like, how bout you?? As far as the 543, it's going in my Challenger. I know I already have a decent running 440, but always wanted something NASTY and this I think fits the bill!! No dyno results yet but it's expected to be about 15 horsepower within 650. I'll post the build specs later. I've got to clean up the engine compartment and replace some wiring before it gets dropped in. Thanks for all the comments and advice. I'll keep yall posted on how these headers fit. They look awesome and seem like top quality!! :clapping: :woo: :woo: :woo:
                                              Matt B.
Matt
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #19 on: March 11, 2009 - 09:56:48 PM »
Looks good bro!!!
Don
Member Since January 14, 2002
Offline 74 340 4speed
« Reply #20 on: March 11, 2009 - 10:09:48 PM »
Nice looking motor!  I like dougs headers too.  I have a set of them on my 67 Camaro and they fit great.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline dutch
« Reply #21 on: March 12, 2009 - 05:07:34 PM »
 :wow:  :drool:  :burnout:
*** Bart ***
nivvy
« Reply #22 on: March 12, 2009 - 05:28:01 PM »
looks good matt.....    :2thumbs:
« Reply #23 on: March 12, 2009 - 09:56:31 PM »
Thanks guys!!
For anyone interested, I posted the engine build specs in the "Proven engine combo" section. Now for the fun part......engine swap!! :woo:
                                                 Matt B.
Matt
« Reply #24 on: March 12, 2009 - 10:26:00 PM »
Well seriously it takes 1 hour to drop the K , I did it two weekends ago in 1 hour 5 minutes,
 then get some snowmobile storage pads , set the K frame with most of the suspension on th epads , load the engine onto the K frame & completely assemble the engine ,starter ,headers ,water pump with pullys & belts , fan ,carb , tranny , dist ...everything . then put 2- 6 ton stands under the front leaf spring hanger & lift the front of the car by hand ....seriously .... have a friend ratchet a stand up to hold the nose of the car up & roll the whole assy under the car & set the nose of the car down , lower the rear as well to keep the car somewhat level , lower the nose down to the K frame , install the 4 K frame bolts , jack the rear of the tranny up & slide in at least 2 of the crossmember bolt & jack up the nose of the car . Once you have done it this way you will never try to install an engine from the top again , this even works with the Hemi
« Reply #25 on: March 12, 2009 - 10:32:23 PM »
Never thought about doing it that way. Sounds like the way to go!! Thanks for the suggestion!! I think the only thing easier would be to pay someone else to do it!! :smilielol: :roflsmiley: :smilielol:
                                                 Matt B.
Matt
« Reply #26 on: March 12, 2009 - 10:41:21 PM »
Well I am bored & getting cabin fever !!
« Reply #27 on: March 12, 2009 - 11:09:15 PM »
If you were closer (by a few hundred miles) I'd be all over that. I usually work solo and could always use a hand, especially trying to do an engine swap!! I'd even buy lunch and cold beverages of choice!! :clapping:
                                                  Matt B.
Matt
« Reply #28 on: March 12, 2009 - 11:18:30 PM »
                                                  Matt B.
We are Only about 3000 miles apart  :pullinghair:
  • Pearl Harbor, HI
    • C-C.com
« Reply #29 on: March 12, 2009 - 11:29:08 PM »
He drinks root beer!   :cheers:
Don
