Compression test numbers
Author Topic: Compression test numbers  (Read 918 times)
Offline 67vertman
  • Member since 9-23-2005
« on: March 08, 2009 - 05:59:05 PM »
I performed the compression test today.  Stock 1970, 318.
I ran the test twice on each cylinder, dry both times except the # 5 cylinder, ran it dry then wet.
Cylinder #
8, 150 – 152 psi
6, 140 – 144
4, 135 – 145
2, 148 – 140
7, 140 – 145
5, 80 – 80 Dry, 95 – 100 wet
3, 145 – 142
1, 138 – 140
The motor has set for six years.  I think the number 5 cylinder is rings.
How do the numbers look?
Re: Compression test numbers
« Reply #1 on: March 08, 2009 - 08:32:30 PM »
looks great except for # 5 , probably both rings & heads , the rings would bump the compression higher with oil generally
Offline 6packCuda
« Reply #2 on: March 08, 2009 - 09:07:19 PM »
I would do a cylinder leakage test on #5. That will help to pinpoint the problem with that cylinder.
Offline 67vertman
« Reply #3 on: March 08, 2009 - 10:57:51 PM »
I was thinking the same thing.  :2thumbs:
All though it means I will have to buy a new tool.   :jumping:  Don't tell the wife though
Offline 71chally416
    • The Streetwalker
« Reply #4 on: March 08, 2009 - 11:38:54 PM »
Sounds like a burnt exhaust valve to me. That's common with a high mileage SBM motor. Could also be a cylinder with some scoring or just the rings are siezed on that piston from sitting for 6 years. Might wanna try some penetrating oil in that one hole over night than run it for a few hours and see if the compression changes. The other cylinders are good for such an old motor.
Offline femtnmax
« Reply #5 on: March 09, 2009 - 12:15:45 AM »
The numbers didn't seem to come up enough for bad rings.  I could be wrong.
If your on a budget, you could pull the head(s) and hand lap the valves (replace one?) so the compression comes up even on all holes, but not enough to overpressure the tired rings which would cause increased oil consumption.  With new valve stem seals could have it running for under $100.... But the plastic timing chain gear on the cam...or.... would be next.....
Phil
Offline 72bluNblu
« Reply #6 on: March 09, 2009 - 03:19:44 AM »
#5 is a valve issue, not rings. In my experience most bad rings will come up to almost normal compression levels with some oil down the cylinder, unless the rings are completely shot. It may not even be a burnt valve, could just be carbon build up on the back of the valve. It might also just be a stuck valve if its been sitting that long, any valvetrain noise?
Offline 67vertman
« Reply #7 on: March 09, 2009 - 12:55:16 PM »
Thanks for the input guys.
I only let it warm up for about fifteen minutes before I did the compression test.  So, I am going to run it up to temperature a couple of times and retest it again and see what happens.  I am not planning on running this motor much right now anyhow.
