Author Topic: 72 Cuda project - GONE  (Read 10640 times)
Offline Jim
« on: March 08, 2009 - 06:18:41 PM »
Okay... I had plans to finish this car, but another car that I have been interested in purchasing has become available. I can't afford both, so I need to sell this quick. If the other car sells, so does my immediate interest in selling the Cuda.
Really too much too list, but I'll give the overview.
Body work is complete with all rust removed. I have front and rear valances for it and an AAR hood. It is set-up for a 70 Cuda grille, which I have. If you want to go with a 72 grille instead, I have a header panel, but no grille. (see update below)
Subframes are tied with welded-in connectors. Radiator support is reinforced across the bottom and it as a six point cage with drop down door bars. Work was performed by a professional racecar fabricator and done RIGHT. This sucker is STIFF.
The car started as a 340 auto column shift, but it is currently set up for a four speed. Hump, pedals and Z-bar bracket are installed.
Front suspension is all powder coated. Pretty much a stock set-up, but with offset bushings so it can be lowered.
Rear suspension is stock HD leaf springs, moved inboard for tire clearance. Axle is a back-braced 8 3/4 with 4.10 gears and a powerlok. Axle housing is powder coated.
Brakes are 13" front with PBR/Cobra calipers. Rears are 11" w/ Ford calipers. This is a Dr Diff kit. Stainless steel brake lines are installed. Braided hoses are includes as are master cylinder, distribution block and adjustable proportioning valve. Need an e-brake cable, but that's it in that department.
Wheels are 18" Foose Montereys with BFG rubber. 245-40-18 front and 285-40-18 rear.
I have an iron head 440 for the car. Everything is machined and balanced, ready for assembly. Just need a cam kit and a few other odds and ends to complete the package.  I'll finish building it on request. Call for specifics.
I also have an Afco aluminum radiator with electric fan and shroud
I have a rebuilt 23 spline 4 speed with clutch linkage and shift linkage. Still needs flywheel, bellhousing and clutch. (see update below)
Interior is custom upholstered leather. Front buckets come out of a late model car (not sure what). Rear is a stock bench upholstered to match. Dash has autometer gauges. I have everything needed to finish the interior, except arm rest pads (repops available). I'm in the process of painting the side side panels. Alpine sound system with four speakers is installed, but still needs an amp. (see update below)
There is over 28 grand invested just in parts, and that's a conservative estimate. There are hundreds of labor hours on top of that.
I'll let it all go for $24K OBRO. (see update below)
Car is located in Evansville, IN
Call me at 812 306 2439 weekdays, or 812 867 3988 after 5 CDT for more details.
j_bossman@yahoo.com
Thanks,
Jim
« Last Edit: February 07, 2010 - 03:04:01 PM by 471_Magnum »
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline 67vertman
  • Member since 9-23-2005
Re: 72 Cuda project
« Reply #1 on: March 08, 2009 - 06:52:39 PM »
Wow, you are selling it?  Seems like yesterday you just got it.
The other car must be a beauty if your selling this one.
Offline Jim
Re: 72 Cuda project
« Reply #2 on: March 08, 2009 - 07:58:14 PM »
I bought the car back in October from a friend.
I'm a bit fickle, but my timing has been awful as of late.
-Jim
Offline Jim
Re: 72 Cuda project
« Reply #3 on: April 14, 2009 - 08:25:17 PM »
Just a quick update.
Got most of the interior installed (minus door panels and front seats). I've also acquired a 72 grille set-up in need of minimal repair. Probably of greater interest, I have acquired a Keisler/Tremec 5 speed.
Consequently, the price has gone up. Now looking to get $26.5K, or trade for NICE turnkey 71-72 Road Runner or GTX (must be bucket seat car).
« Last Edit: October 23, 2009 - 01:17:29 PM by 471_Magnum »
-Jim
Offline Super Blue 72
    • Phil's Super Blue '72
Re: 72 Cuda project
« Reply #4 on: April 14, 2009 - 08:31:36 PM »
Wow!  Just want to say that's a great looking car!  :grinyes:
Offline dixiedog
Re: 72 Cuda project
« Reply #5 on: April 15, 2009 - 10:30:38 AM »
 :droolingbounce: beautiful car, I would keep it just to look at it, wouldn't get any sleep though.
Offline Jim
Re: 72 Cuda project
« Reply #6 on: July 05, 2009 - 03:43:19 PM »
Still muddling along on the project. Started assembling the short block, but it's all still for sale.
-Jim
Offline Jim
Re: 72 Cuda project
« Reply #7 on: August 28, 2009 - 07:12:12 PM »
bump
-Jim
Offline 4402go
Re: 72 Cuda project
« Reply #8 on: September 22, 2009 - 05:03:03 PM »
 So did you sell this car ? I was just talking to a friend of mine and told me about a cuda he saw in town and described it to me. I thought it sounded familiar. He pretty much described your car. I'm in southern Ontario. He told me dark red and side all silver, with big aftermarket rims. What are the odds ? If not then this will bump it to the top again.  Oh and the price was right in line with your asking price, and believe he said it came from Chicago area ? Also think the guy was driving it ?
« Last Edit: September 22, 2009 - 05:07:12 PM by 4402go »
Offline Jim
Re: 72 Cuda project
« Reply #9 on: September 22, 2009 - 05:23:58 PM »
Mine is still in my garage... and still for sale.
-Jim
Offline 4402go
Re: 72 Cuda project
« Reply #10 on: September 24, 2009 - 12:03:55 PM »
Really !!! Well now I'm really curious to see this other car. Sounded just like yours the way he told me, and doesn't go on-line either, so I know he's not trying to get me going. Well if I see it I'll take some pics.  Good luck with the sale.
Offline Jim
Re: 72 Cuda project
« Reply #11 on: October 23, 2009 - 01:16:58 PM »
BUMP.
Just finished assembling the 440. One less thing for a prospective buyer to deal with.
Buy now and have it ready for SPRING.
-Jim
Offline Jim
Re: 72 Cuda project
« Reply #12 on: November 08, 2009 - 08:10:26 PM »
Did some more work on it this weekend. Got the front valence mounted as well as some other odds and ends. Pushed it into the sun to take some pictures. Then I whipped up a CarDomain page.
You can check it out here:
http://www.cardomain.com/ride/3806708/1
-Jim
Offline Jim
Re: 72 Cuda project
« Reply #13 on: December 03, 2009 - 08:05:27 PM »
Bump bump bump
Price reduced to $25K. If no one nabs it at this price, I'm just going to finish the thing myself... someday.
« Last Edit: December 04, 2009 - 11:42:06 AM by 471_Magnum »
-Jim
Offline troutstreamnm
Re: 72 Cuda project
« Reply #14 on: December 04, 2009 - 11:01:02 AM »
Oh man.....I wish I has $25K for this one.  Someone is going to get a hell of a car to finish out
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
