Author Topic: Busted studs...  (Read 1312 times)
Offline elevenssc
Busted studs...
« on: March 09, 2009 - 09:11:18 AM »
I've gotten the rear leaf springs out of my 1970 Barracuda after wrestling with almost 40 years of rust and "yuck".  I'm replacing the old rubber suspension gromets with polyurethane.  In the process I've busted off a few studs,  :22yikes: and I'm curious where is the best place to get parts to replace the broken stuff.
First off...U-bolts.  I see Paddock has replacements for ~$80.  Anyone else have a better recomendation?
Second, The lower DS rear shock mount stud.  I twisted off the nut and it broke right where the threads ended.  The shock mount portion is still in tact, but the threaded portion busted off.  This is the plate that the U-bolts bolt thru to hold the leaf springs to the rear axle.  I think I need the whole plate, but looking at the PS bolt on the same plate, it looks to have been broken and welded back on.  Any recomendations?
Third, and last, the studs that hold the front leaf spring mount shackle to the frame...there are 4 studs for each side.  I broke one stud on the DS and one on the PS.  Any recomendations where I can get replacement studs?
It's always a joy twisting on fasteners that have had 40 years to seize themselves together...especially considering the Minnesota winters the car endured early in it's life.
If any pics are needed, let me know...I can get them.
Thanks in advance...
Re: Busted studs...
« Reply #1 on: March 09, 2009 - 12:08:34 PM »
the studs are sold seperatly to replace the broken shock mount stud Try Dave at Roseville
 U bolts I get locally from a suspension shop for $8 each ,
the stud for the spring hanger may be available from Dave as well
Offline wally426ci
    • maryland mopars
Re: Busted studs...
« Reply #2 on: March 09, 2009 - 12:22:10 PM »
I couldnt help but think you were referring to Big Breasted Body Builders when I saw the title.....  :misbehaving:
 :roflsmiley:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline usraptr
Re: Busted studs...
« Reply #3 on: March 09, 2009 - 12:26:21 PM »
 :iagree: with Chrysler Psycho.  My local suspension shop said they make me brand new U bolts for $12 each.
(Edited 8-1-17)
Offline elevenssc
Re: Busted studs...
« Reply #4 on: March 09, 2009 - 02:38:36 PM »
This is a newbie question...
Dave at Roseville...How do I contact him?...does he have a website?
Thanks
Offline elevenssc
Re: Busted studs...
« Reply #6 on: March 09, 2009 - 08:30:03 PM »
Since I took photos...figure I'll post-em...
Limited searching has not found any replacement studs yet.  I'm thinking RT Specialties may have the studs for the forward rear leaf spring mount.  Nothing yet on the shock mount...
Alaskan_TA
Re: Busted studs...
« Reply #7 on: March 09, 2009 - 08:40:34 PM »
I have a new stud for the front mount. I needed two & had to buy 10.  :screwy:
Offline elevenssc
Re: Busted studs...
« Reply #8 on: March 09, 2009 - 08:42:31 PM »
needed 2...had to buy 10...that leaves 8???
I'd be interested in replacing all 8 if possible...
Alaskan_TA
Re: Busted studs...
« Reply #9 on: March 09, 2009 - 08:48:57 PM »
Not a problem, I had to pay 3 bucks each, that OK? Postage should be under 5 bucks I would think.
Offline elevenssc
Re: Busted studs...
« Reply #10 on: March 09, 2009 - 08:55:33 PM »
I'll take the 8 off your hands...Sold!
Should I use your 1970 Hamtramck Registry address?
Just curious...did the studs come with nuts and washers, or just studs?
Alaskan_TA
Re: Busted studs...
« Reply #11 on: March 09, 2009 - 09:08:25 PM »
I only have the studs. Email me with your mailing address, I should be able to mail them tomorrow.
The Hammy mailing address is fine, so is a personal check, just make it out to Barry Washington.
Offline elevenssc
Re: Busted studs...
« Reply #12 on: March 09, 2009 - 09:34:09 PM »
Will Do!!!
Alaskan_TA
Re: Busted studs...
« Reply #13 on: March 10, 2009 - 08:45:31 PM »
They are on the way.  :wave:
Offline elevenssc
Re: Busted studs...
« Reply #14 on: March 11, 2009 - 10:15:02 PM »
Just an update for future reference...
1) U-Bolts for 8-3/4" rear end from Just Suspensions...4 for $40
2) Rear lower shock stud from Just Suspensions...$20/pc (Plates and Studs are $170..I'm replacing the studs in my existing plates...we'll see how that goes).
3) Front leaf spring shakle studs...Thank You Mr Barry!!!
It's always nice having a bunch of folks like you to fall back on when things "happen".  This place is great!!! :woohoo:
