Author Topic: Steering rack compatibility question  (Read 630 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: March 09, 2009 - 07:06:47 PM »
Anyone tried to use a new '05 Charger rack and pinion setup?
I found one for supercheap. Wondered if it was easily done - Yeah, right.
I will assume custom bracketry, some longer tie rod ends...
Anyone?
Dan
Offline 72bluNblu
Re: Steering rack compatibility question
« Reply #1 on: March 20, 2009 - 02:51:39 PM »
I don't know much about the dimensions of the charger rack, although I do know that the aftermarket rack and pinion conversions for the e-body aren't that good. To get the rack to work with the stock suspension usually results in some serious bump steer, the only versions I would go with come with the aftermarket K frames as they use different suspension geometry.
Offline T569Bee
« Reply #2 on: March 23, 2009 - 11:36:44 PM »
Way too long to work an an early E or B body .
Offline DMZ73
« Reply #3 on: March 24, 2009 - 09:29:05 PM »
Good input. Great advice.
I will stay away from delving into this mess....
Dan
