Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Compression Test?
« previous
next »
Print
Pages: [
1
Author
Topic: Compression Test? (Read 498 times)
Glennster
Full Member
Compression Test?
on:
March 09, 2009 - 08:24:16 PM »
What is the difference between a dry and a wet compression test?
Thanks!
Logged
67vertman
Sr. Resident
Member since 9-23-2005
Re: Compression Test?
Reply #1 on:
March 09, 2009 - 08:51:17 PM »
Dry is when you warm it up and then just turn it over. Wet, you pour some 30 wt oil in the cylinder and run the test. I usually pour about a tablespoons amount of oil in the cylinder.
Logged
Current ride - 1970 Barracuda 440-6 4 sp Dana 60 (4:10)
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
March 10, 2009 - 01:32:30 AM »
if the rings are bad you will see a jump in compression with oil in the cylinder , if the valves are bad you will see marginal gain with oil
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Compression Test?
