Author Topic: 8 3/4 Rear End Identification...  (Read 1211 times)
Offline elevenssc
« on: March 09, 2009 - 08:25:46 PM »
Mopar Newbie here with a Newbie question.  (I cut my teeth on the Ford 8.8" rear end in a Fox Chassis, so leaf spring Mopar's are a whole new world to me...)
I was pretty confident that I had an 8-3/4" rear end under my Cuda until I was searching for U-bolts and found a listing for 8 1/4".  Is there such a thing as an 8-1/4"???   :clueless:  I know there's an 7-1/4", 8-3/4" and 9-3/4" (aka Dana 60??), but the 8-1/4 threw me...(maybe it's a type-o?)
Regardless, I'm attaching photos of what's under my car.  The ring and pinion need to come out the front of the rear end housing.  According the the shop manual I have, both the 7-1/4" and 9-3/4" rear ends require the ring and pinion to come out the back of the housing, 8-3/4 coming out the front.
Just making sure I get the right U-bolts...Which leads me to another question...When manufacturers describe U-bolts as being 7", 8" or 9", are they identifying which rear end they fit, or is it the length of the U-bolt?
Offline sprecks
Re: 8 3/4 Rear End Identification...
« Reply #1 on: March 09, 2009 - 09:08:54 PM »
That's an 8-3/4 you have there. Chrysler did make an 8-1/4 and 9-1/4 too. The 8-3/4 is the only one that is front loaded, all others have rear end covers.
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline elevenssc
« Reply #2 on: March 09, 2009 - 09:32:01 PM »
Thanks!!!
« Reply #3 on: March 09, 2009 - 09:33:04 PM »
8 inch bolts would work. I believe 7 is stock
« Reply #4 on: March 10, 2009 - 01:25:45 AM »
you need a round top 3" diameter ID, 1/2" ,  7 " long U bolt
