Offy are a single plane with a divider, this intake is a dual plane like the six pack and stock manifolds. Yes the plenum connect both front and rear carbs.
I will agree the newer RPM intakes and a 650-750 DP carb are very hard to beat...what I am running now.
I would "love" 15 MPG on the highway...I get 9 MPG now but driven stop and go and not pussy footing around.
But right now its running very well, I could give up a bit of power and still hang with many around my area. I have a nice clean AVS 4615 and it ran smooth around town but was off the power-but still pulled good at top end, so if I have two AVS like the Super Stockers ran but then elect choke is nice. I have one of those 600 Eddy carbs rebuilt and that AVS...might have to lighten up the seconday weights on the Eddy and like one turn on the sec. spring.
I'm getting "old" too, if I can tune it for a bit more MPG for long highway trips and still can have a good pull the second I punch it--and it runs smooth at all rpms, I be happy, even if power is off a bit.
I think tuning is going to be the key, spacers-open and 4 hole, jetting, secondary timing....yeah about the sharp corners at the bottoms of the throttle bores should be rounded off to a 1/2 inch minimum radius so fuel stays mixed better rather than shearing and seperating. Might be true but I'm also running a hot MSD 7 al box and HVC coil with a E-curve msd dist..(got it while times were good)...it really helps to burn the fuel up, even running a little rich the plugs stay clean -but times go down.
Besides some 6 inch air filters and I have the "oh wow" factor down good...maybe be a "chick magnet", lol
