It RUNS, runs good.
Tried .083, .077 and then could tell it was lean (wasn't missing but part throttle pulled hard but not much change as it went to WOT so it has .080 in and seems pretty darn good.
Low end is better, its still 1 to 1 but going to try progressive when I get to it. (would just leave it but MPG isn't so great but then my 1/4 throttle power will be weak.
Going to call Edelbrock and see about getting different weight air doors for the secondaries--at least 2 stock ones to play around with. Seems in first with my 3.91 gears and 2.74 first gear it flies open fast but who knows, maybe it could become even better than with that Demon carb.
It starts nice, idles nice..its 65 degress out here today and carbs are cool to the touch shutting down and intake is very warm but doesn't burn your fingers.
I tried a cold intake before, up here it isn't as good. All the fuel doesn't burn it seems, the exhaust stinks of unburn fuel no matter the jetting with a cold intake and under 70 degress outside. I'm using a MSD 7al box and HVC coil to fire racing A/C spark plugs--not store rapid fire but from a NASCAR seller on Ebay..they had hot enough plugs for street use.
EBAY, if you can take your time and get lucky its a gold mine of old stuff, some brand new..both carbs were brand new, one made in 1998, the other 1999. Got the last ones before Edelbrock took over. No vacuum ports or choke linkage, very clean looking. Using Carter linkage too, nice and simple one rod, not two like Edelbrock has.
For you big block guys, Edelbrock still makes a dual plane intake, put two 600 or even 750 carbs and enjoy better low rpms, I was a Holley-Demon lover but not going to miss them anymore.
