Author Topic: Carter Thermoquad Question???  (Read 6701 times)
Offline cjm
  • 70 Cuda - In Progress.....
« on: March 10, 2009 - 08:36:45 PM »
I have a Thermoquad with the numbers 2124 stamped on it. Dos anybody know what size this carb is ? 750?? 800???
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Carter Thermoquad Question???
« Reply #1 on: March 10, 2009 - 08:44:46 PM »
Here's soome info on tq's... hope it helps but I don't see that #.  :dunno:
http://carburetor.ca/Tech/Carter/tqguide-Vaanth.html
"1-3/8" bores are listed as 750-800 CFM and those with the 1-1/2" primary throttle bores are rated at 800-850 CFM"
« Reply #2 on: March 10, 2009 - 09:04:43 PM »
Here's a link that lists all the T/Qs Chrysler used...your number is not on the list but look again at your base plate back/drivers side & see if there is another number
http://members.shaw.ca/crussel/thermoquad/tqguide.html
Offline cjm
« Reply #3 on: March 10, 2009 - 09:33:08 PM »
Thanks for the replies... It does have a 6 before it, I didn't notice that before...   Definitely 6-2124 .... I will check the bore size tomorrow in better light.................
Offline vinb
« Reply #4 on: March 11, 2009 - 08:46:13 PM »
That number on the top of the carb the 6-2124 I believe is a casting number. You need to look at the number on the base plate in the rear driver side. It should be a 4 digit number with a letter s /stick or a /auto begining with a 4, 6 or a 9 and end with a letter. 6138SA or 9810S..Check the list that the other guys posted early..
Let us know.....
Offline cjm
« Reply #5 on: March 14, 2009 - 10:40:25 AM »
These are the numbers on the base plate (driver's side rear)
oo19S
264 - 2
Could this possibly be from a marine engine?
« Reply #6 on: March 14, 2009 - 11:26:55 AM »
Probably does not matter...
found this interesting
"TQs with 1-3/8" primary throttle bore will have '2-315' stamped on the
throttle plates. 1-1/2" units will have '2-314' stamped on the plates.
All secondary plates are stamped with '2-312'."
Rebuild Kits don't seem to change between CFMs but do change over the years, if you post a pic we probably could at least steer you to the correct kit.
