Author Topic: small block valve cover gasket question  (Read 832 times)
Offline resq302
« on: March 12, 2009 - 11:13:39 AM »
What kind of material was used on the small block valve cover gaskets?  I am working on a 70 chally convert and the fel pro engine rebuild gasket kit that I got has what seems to be rubber valve cover gaskets.  I would like to use whatever the factory used since it is going to be a factory appearing car.  My initial thought was that they were cork originally?  Am I wrong in my thought?  Also, the tabs that stuck through were probably engine color as I would have to assume that they were on the engine prior to it being painted.
Thanks,
Brian
Offline cuda-cable
  • MOPAR or no car
Re: small block valve cover gasket question
« Reply #1 on: March 12, 2009 - 12:23:26 PM »
I replaced those back in the early 70's , they were cork, and the tabs stuck thru the sides........they leak easily, so I'd use RTV.....dk
Offline acudanut
« Reply #2 on: March 12, 2009 - 10:43:53 PM »
Whose going to see either gasket ??  I would use the rubber fel-pro.  :2cents:
Offline resq302
« Reply #3 on: March 13, 2009 - 12:08:32 AM »
where the tabs stick out from the valve cover..... everyone would.
Offline 71chally416
    • The Streetwalker
« Reply #4 on: March 13, 2009 - 12:10:20 AM »
Cork is the suck. It's only good for the end of a wine bottle.  :lol:
