will it not idle on the idle circuits ?
if not you need to drill holes in the throttle plates to allow more air in while keeping the throttle plates closed to allow the idle transfer slots to work , also there is idle screw in the front of the base plates of the outboard carbs , adjusting them may help also ,, you will need to get a vacuum reading idling in gear , the power valve may need to be lowered to a 2.5 or lower to stay closed at idle also
