Author Topic: posi yoke swap  (Read 595 times)
Offline moparnut
    • My Photo's
posi yoke swap
« on: March 14, 2009 - 12:18:55 PM »
ok i want to swap the 323 open chunk with a 355 suregrip in my GC.
How do i swap the driveshaft yokes from one to the other?
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline moparmaniac59
  • Drive it like ya stole it!
Re: posi yoke swap
« Reply #1 on: March 14, 2009 - 12:28:58 PM »
You should just loosen the center nut from the yoke and slide off of the the spline. If you have a 489 case the crush sleeve/pinion depth is set by tightening the yoke nut. So by loosening it up you will have to re-set the pinion depth. If it is a 742 case, the pinion depth is set with shims, so swapping yokes, removing and retightening the yoke nut wouldn't be a problem. I know some folks that have very cautiously removed the yoke and reinstalled it on a 489 case and been careful not to tighten it up enough to further crush the crush sleeve and been fine. If you have a good feel you can tell if you are tightening it up to the point of adding further crush to the sleeve (on a 489 case). It takes a lot of torque to crush it. Hope I didn't confuse you!!
                                                  Matt B.
Matt
Offline moparnut
    • My Photo's
Re: posi yoke swap
« Reply #2 on: March 14, 2009 - 12:52:42 PM »
thanks :2thumbs:
Re: posi yoke swap
« Reply #3 on: March 14, 2009 - 02:22:11 PM »
there are also 10 & 30 spline yolks , if the nut is the same size on both they are the same spline if the nut is a different size the spline is different so just leave it alone
