Carb rebuild
Author Topic: Carb rebuild  (Read 4947 times)
Offline 67vertman
  • Member since 9-23-2005
Re: Carb rebuild
« Reply #15 on: March 20, 2009 - 10:20:38 PM »
I noticed the HUGE increase on the gallon paint cans of carb cleaner at NAPA, 53 bucks.  I passed on that and found berrymans at autozone for 19.99.  soaking for a day or 2 works better than just spraying, IMO
Thanks for the tip solarguy.  My carb is pretty clean. But when I pull it apart tomorrow if it need a deep cleaning I will check it out at Autozone.
Offline 67vertman
Re: Carb rebuild
« Reply #16 on: March 21, 2009 - 07:41:41 PM »
The carb rebuild went well.  :clapping:  The only minor issue was that the rebuild kit had a different accelerator pump than the original.  A round shaft compared to a flat shaft for the original, but the original was in good shape so I lubed it and reused it.
It has a slight stumble off idle that I can’t tune out though.  :clueless:
Offline solarguy
Re: Carb rebuild
« Reply #17 on: March 22, 2009 - 11:45:16 AM »
that could be a worn accelerator pump.  can you carefully remove the cup seal from the new one and put it on the other shaft?  That is assuming they are the same size cup seal?
« Last Edit: March 22, 2009 - 11:47:23 AM by solarguy »
Offline 67vertman
Re: Carb rebuild
« Reply #18 on: March 22, 2009 - 02:51:37 PM »
I was thinking the same thing.  I am going to the place I got the carb kit from to see if they have the correct one.  If not, I may try to switch out the cups.
Offline 71chally416
    • The Streetwalker
Re: Carb rebuild
« Reply #19 on: March 23, 2009 - 12:20:16 AM »
Just look down inside the carb with a light. Any slight movement of the thottle should make gas squirt out the nozzels. If it takes more than just slight movement you'll have a stumble. Make sure that linkage that goes to the pump arm is adjusted like the kit says.
