Author Topic: What K-frame is this?  (Read 773 times)
« on: March 17, 2009 - 07:19:50 PM »
Hello!
I bought this last weekend thinking it was a Challenger (e-body) K-frame when I got it home I quickly realized it wasn't as the sway bar won't fit. So what is it? pre-70 B-body? If so is every thing the same except for the sway bar mount? The guy I bought it off will gladly give me my money back so that's no problem. I need to know if everything else is the same as I was considering mounting a Schroeder sway bar set up in it.  It's in really good shape!
Offline sixpakchallenger
Re: What K-frame is this?
« Reply #1 on: March 17, 2009 - 07:32:13 PM »
I would guess 68 t0 69 B-Body.
This is a E-Body K
2004 Ram 2500 4X4
2007 Mustang GT Convertible
1971 Dodge Challenger Convertible
« Reply #2 on: March 17, 2009 - 08:33:41 PM »
it has the 4 holes for mounting the sway bar on the front lip of the K so yeah it is a 66-70 B body
 the steering box mount angle is supposed to be different between E & B body
« Reply #3 on: March 17, 2009 - 08:37:12 PM »
Thanks , do you know in what axis it is different? Is that all the differences? Will it bolt up otherwise?
« Reply #4 on: March 17, 2009 - 09:09:58 PM »
it will bolt in , not sure if the seering box is angled higher on the B or the E body ?
« Reply #5 on: March 17, 2009 - 09:33:23 PM »
So your saying the pitman arm will be higher or lower than a e-body K-frame? Is that the way you mean? Just so I understand how you mean?
Thanks again!  Brad
« Reply #6 on: March 17, 2009 - 09:43:17 PM »
no , more the angle of the steering box to the steering column will not be straight
