The size of a carb has nothing to do with "Washing the rings out".
The calibration does. The old standard Holley 3310 or any of the clones should work OK but my choice on ANY SB Mope is the carb many of them came with, including some 318's, the Thermoquad. Failing that, the other carb they came with would be my choice, the AVS (Thunder series Ed carb) that bolts on a square flat Intake. If the 318 was all stock with stock exhaust I'd stay small, but with your mods I'd go bigger. You find on the engine dyno a seemingly "too big" carb never hurts hp. It just flattens out the TQ curve and helps the car move down the track better. BTW, every single fast SB Mope you'll see racing stock and super Stock has a Thermoquad on it. They have to use the stock part # carb that came from the factory.
None used Holleys from the factory but the 6 pak cars.
