70 e-body how long is the steering shaft?
Author Topic: 70 e-body how long is the steering shaft?  (Read 1474 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: March 18, 2009 - 04:06:15 PM »
How long is the 70 e-body drive shaft? Mine is 38 and 1/2". Has mine colapsed a little? The reason I'm asking cause  I can't get me steering colunm installed do to it beeing to short to reash the steering gear box. This problem came after I restored the steering colunm.
« Last Edit: March 18, 2009 - 04:10:20 PM by widing'cuda »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline 422STROKER
  • Member Since 6/3/06
Re: 70 e-body how long is the steering shaft?
« Reply #1 on: March 18, 2009 - 05:29:28 PM »
I couldn't get that exact measurement but from the base of the crush can to the tip of the shaft was 40", and to the top of the crush can I get 45".
Hope this helps I believe there are some plastic roll pins in there that allow the column to collapse in an accident.
Tom
BTW where did you get the gaskets etc?
Tom
Offline sixpakchallenger
« Reply #2 on: March 18, 2009 - 05:36:38 PM »
Power steering shaft is about 40.5 inches from the threaded end to center of the dowel pin, manual steering is about 43.5
2004 Ram 2500 4X4
2007 Mustang GT Convertible
1971 Dodge Challenger Convertible
Offline widing'cuda
« Reply #3 on: March 18, 2009 - 05:41:32 PM »
Got the gaske etc on eBay over time...
So that means mine is 2 inch to short...  So my steering shaft must have collaps then. I'm missing one of the roll pins as fare as I can see.
Offline widing'cuda
« Reply #4 on: March 18, 2009 - 06:35:16 PM »
Upper shaft is 13.3/4" and lower shaft is 24" = 37.3/4" So that mean mine has collaps? It looks liek one pine is missing. But it looks like one is there tough or is this somting else?
« Reply #5 on: March 18, 2009 - 06:51:18 PM »
They are not pins, its where the plastic was injected.
2004 Ram 2500 4X4
Offline widing'cuda
« Reply #6 on: March 21, 2009 - 06:00:04 AM »
OK  :thumbsup:
I guess i have to pull mine apart. how do I set it back together again?
