I'm running bronze guides too, but I have heard many comments that don't like them. Too fast a wear rate, or.... David Vizard suggests them in his books for their lubrication qualities, especially for lifts above 0.50.
On the issue of valve stem oiling, a little extra oil on the exhaust stems helps lube the hot valve stems, and helps the heat to transfer from the stem to the guide. Remember the exh valve and spark plugs are the two hottest locations in the combustion chamber.
So I run NON-positive type valve stem seals on the exhaust. Some circle track racers I know don't run ANY stem seal on the exhaust, this stopped valves sticking in the guides. I'm not running a positive type seal on the intakes anymore either, letting a little oil onto the stem should help with valve guide wear. There's probably an infinite number of opinions to your question, this is JMO. I don't know if there's anything wrong with using what you have suggested, but I would not use positive stem seals on the exhaust.
The biggest B**ch I have from head work at machine shops is the sloppy valve to guide fit. There are ideal clearances, and the looser the fit beyond specs the quicker the guides will wear, and the more out-of-round the valve seats are. It's All bad bad bad.
