Ballast Resistor, do I need to have one?
Author Topic: Ballast Resistor, do I need to have one?  (Read 1533 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: March 21, 2009 - 07:42:47 AM »
I check around in the engine room today and noticed that I don't have Ballast Resistor. The wites are juste spilced were it should go.  Is this something I should have?
My setup is Mallory dual points distributor with mechanical advance and PerTronix Flame Thrower II coil. Wiring is stock (YearOne repro)
« Last Edit: March 21, 2009 - 08:28:50 AM by widing'cuda »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline ChallengerGary
    • Challenger Gary
Re: Ballast Resistor, do I need to have one?
« Reply #1 on: March 21, 2009 - 10:08:14 AM »
I believe you really do need one. It's purpose, irc,  is to drop the voltage to the coil.  Without it, you could overload the coil and end up with a dead car.
Where is Chryco?  I am sure Neal can answer this question unequavically for you....
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline widing'cuda
« Reply #2 on: March 21, 2009 - 10:10:55 AM »
OK. I've dirven the 'cuda without one for about three years now.
Offline Changin Gears
« Reply #3 on: March 21, 2009 - 11:26:40 AM »
The ballast resistor limits the current through the coil.  Its part of a feedback system.  At low RPM the coil is easy to  saturate and would get too hot.  How the system works is when the coil starts drawing alot of current, at low RPM, through the resistor, the resistor heats up.  As the resister heats up, its resistance goes up, limiting the current that will be available to the coil.  The opposite happens at high RPM.
When you turn the key to the 'start' position the resistor is bypassed, supplying full battery voltage to the coil.  This is because while cranking then engine the battery voltage drop 2 or 3 volts.  If you watch an engine being started at night, with lousy plug wires, you can see the voltage overpowering the plug wires and arcing to the heads.
Some aftermarket coils come with their own matched resistor.
« Last Edit: March 21, 2009 - 11:33:24 AM by Changin Gears »
Offline 73EStroker
« Reply #4 on: March 22, 2009 - 12:09:33 AM »
To cut a long story short - with a stock Chrysler ignition you need the ballast resistor. With aftermarket digital boxes and aftermarket coil systems you do not need the resistor.
Barry (Salmon Arm)
« Reply #5 on: March 22, 2009 - 09:05:45 AM »
You don't like my long story?
Offline 73EStroker
« Reply #6 on: March 22, 2009 - 11:43:21 AM »
I like it and yes .... you are 100% correct. I thought he needed the short answer to save his coil.
Barry (Salmon Arm)
