Author Topic: Hamtramck Car question  (Read 2879 times)
Offline 71GTX
  • It's a fine line between a hobby & mental illness!
« on: March 21, 2009 - 08:51:35 AM »
Hey Folks!
Is there any way to verify the number of 1970 Cudas that rolled off the assembly line ahead of mine?? I do not have the Fender Tag in front of me, but from memory the date stamped in it is Aug 26th.....
69 RoadRunner (clone)
70 Cuda 383 4 speed (project) one of the first few off the line at Hamtramck with a 1017XX VIN
70 Cuda convertible 340 4 speed (project)
70 Barracuda (project)
71 GTX 440 4 speed (project)
72 Cuda 340 3 speed (project)
3 Harleys
95 Dodge Ram 2500 Diesel 4x4
Expensive Pee is the end result of Expensive Beer!
Alaskan_TA
Re: Hamtramck Car question
« Reply #1 on: March 21, 2009 - 01:04:54 PM »
Nope, no way to know.
The numbers from 100001 up to yours included 4-door Valiants, Dusters, Challengers & Barracuda models.
Also, the cars were not built sequentially by VIN number, so trying to determine what you are after is impossible unless a full set of build records surfaces.
Offline 71GTX
« Reply #2 on: March 28, 2009 - 02:23:19 AM »
Thanx for the answer Barry! Not what I was hoping for, but its an answer nonetheless!  :2thumbs:
3 Harleys
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #3 on: March 28, 2009 - 08:56:31 AM »
Was August the first month for the E-bodies?   :clueless:
Assuming your Schedueled build date is August 26, 1969,  you must have a low VIN #.
Alaskan_TA
« Reply #4 on: March 28, 2009 - 12:26:52 PM »
August 1, 1969 was the first day of the new model year at Hamtramck for all models.
« Reply #5 on: March 28, 2009 - 04:03:46 PM »
Cool, thanks Barry!   :thumbsup:
« Reply #6 on: March 29, 2009 - 03:16:52 AM »
his serial # should be 109XXX or 110XXX as mine is built about 4 days later
Alaskan_TA
« Reply #7 on: March 29, 2009 - 01:19:34 PM »
I do not have any Barracuda models on file yet with a 826 SPD & he was going from memory, so.....  :dunno:
Offline 71GTX
« Reply #8 on: April 06, 2009 - 08:58:42 AM »
EN1
M88 N41 N42 R11 Y5X Y05
FY1 C16 C55 J45 M21 M25
FY1 H6X9 000 820 017578
E63 D21 BS23 N0B1017XX
Now please keep in mind, that the tag was read by someone other than me. I can only report on what I am being told....and I see that its Aug 20th....
I will also bring up something again that I had mentioned a few years ago....
http://www.cuda-challenger.com/cc/index.php?topic=12691.msg128063#msg128063
The tail panel appears to be original to the car, but sports the 3(three) holes for the "BARRACUDA" insignia.
Could this early production Cuda have gotten released without all of the "proper" badging from the factory?? Or could the Cuda badging on all tail panels happen AFTER the release of mine?? Would love to hear of someone elses car from Hamtramck that is prior to mine or shortly after....
August 1969
 S  M Tu  W Th  F  S
                      1   2
 3   4  5   6   7  8   9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31
« Last Edit: April 06, 2009 - 11:18:19 PM by 71GTX »
3 Harleys
Offline 71GTX
« Reply #9 on: June 26, 2009 - 11:14:41 PM »
~bump~
3 Harleys
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #10 on: July 01, 2009 - 11:28:23 PM »
huh?
