Author Topic: Brake pedal height  (Read 617 times)
Offline MR291
Brake pedal height
« on: March 22, 2009 - 01:31:26 PM »
I just finished my conversion from four drum manual to power front disc brakes.  Everything looks good except the pedal seems a bit low.  Is there a difference between manual and power brake pedals, other than the different linkage.  What should the pedal height be off of the floor?
Appreciate any help.
Re: Brake pedal height
« Reply #1 on: March 24, 2009 - 01:17:32 AM »
is it close enought to activate the brake light switch ? if so I would say you are OK
 the only adjustment is cutting & welding a piece into the pushrod
Offline MR291
« Reply #2 on: March 24, 2009 - 07:04:29 PM »
Thanks.
