I'd rather start with 1.88 heads than 2.02 heads, especially if the 2.02 heads have already been worked on. Then when you install the bigger valves and do your VJ you can have the highest possible seats and the best possible port flow. If a valve is sunk .050" into the chamber to try to correct seat runout then that's .050" off your effective cam lift. Your .450" lift cam now has .400". I've seen many sunk worse than that.
That being said, there isn't a whole lot of difference in the later SB heads. Some have a nice thermactor boss lump in the floor of the exhaust that actually helps flow on the flow bench, but otherwise they have the same flow potential as the earlier 2.02 heads.
