Author Topic: DISTRIBUTOR VACUUM ADVANCE  (Read 1007 times)
Offline cudaneil
  • Mopar or Nocar ?
« on: March 23, 2009 - 06:38:07 AM »
 :2thumbs: hI,
                 Can anyone tell me how much advance your vac/adv distibutor should give ?  (how many degrees)
                                                            :cheers:Neil.
just one more job to do..................  (O----{|||}----O)
Offline cudaneil
  • Mopar or Nocar ?
Re: DISTRIBUTOR VACUUM ADVANCE
« Reply #1 on: March 23, 2009 - 07:46:04 PM »
:2thumbs: hI,
                                                            :cheers:Neil.
                      Can anyone answer this one ?
« Reply #2 on: March 23, 2009 - 08:39:42 PM »
I don't think anyone knows for sure, the same subject is being discussed in this thread w/o a definitive answer
http://www.cuda-challenger.com/cc/index.php?topic=56317.msg581253#msg581253
Don't think it's a # but tuning ...read #8 below
« Last Edit: March 23, 2009 - 08:59:15 PM by Bullitt- »
« Reply #3 on: March 24, 2009 - 12:08:30 AM »
generally you will get about 20* of Mechanical advance , you can weld the slots closed a bit to limit the advance
 the vacuum pots are different the arm has a # stamped on it that tells how much advance they can add , they can be adjusted with an allen wrench on most electronic dist , turning the wrench counterclockwise will reduce the amount of advance
Offline cudaneil
  • Mopar or Nocar ?
« Reply #4 on: March 26, 2009 - 08:28:13 AM »
  MANY THANKS BULLITT AND CHRYCO, THATS A BIG HELP !       :cheers:   Neil.          :england:
