Author Topic: OIL PRESSURE ? WHAT IS THE HIGHEST YOU CAN GO  (Read 1683 times)
Offline Zack Mckellips
« on: March 23, 2009 - 11:00:06 AM »
I STARTED THE 383 COLD FOR ENGINE BREAK-IN AND PEGED THE GAUGE AT 100
Re: OIL PRESSURE ? WHAT IS THE HIGHEST YOU CAN GO
« Reply #1 on: March 23, 2009 - 11:39:43 AM »
That is high. Did it drop any after the engine warmed up?
« Reply #2 on: March 23, 2009 - 11:55:23 AM »
I RAN THE ENGINE UP TO ABOUT 180 DEGREES AND IS WAS STILL AROUND 80-90 PSI THE ENGINE SEEMED TO BREAK IN GOOD, I COULDN'T GET IT TO IDLE I HAVE TO TUNE THE CARB YET
Offline moper
« Reply #3 on: March 23, 2009 - 11:59:52 AM »
Sounds too high to me. With a HV design, usually they will run higher when cold, but as the oil heats, it drops to around 70-80. IMO, that's still too high. But it makes people feel better about things.
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #4 on: March 23, 2009 - 04:38:21 PM »
I had 50-70psi in my new sb motor with hv pump. 80-100 is pretty high in my opinion.
« Reply #5 on: March 23, 2009 - 06:24:59 PM »
Another variable...Were you using heavy oil to break in the engine? Like 20W-50, or such?
wagesofsin
« Reply #6 on: March 23, 2009 - 06:55:41 PM »
umm, another variable here is the guage.
 its just a number. unless its a brand spankin new digital gimmick that was calibrated.... :blah:
i would hook up an external guage to any newly built motor just for safetys sake.
better safe than sorry, and it will only cost a few bucks.
same thing on the temp. just my  :2cents:
« Reply #7 on: March 23, 2009 - 06:59:21 PM »
I know you can blow the rubber seal out of the oil filter. If you have all brand new rotating parts and an hv pump, it can hit 150 psi. Mine did and blew the filter off. Had to go back and change the pump out. If you dont use full groove bearings and have tight side clearances, it is possible
« Reply #8 on: March 24, 2009 - 02:00:46 AM »
my engine runs the same , with 10-40 oil & tight internal clearance very likely , no problems with my 440
 BTW I had a 440 idle at 175 once
« Reply #9 on: March 25, 2009 - 02:45:35 AM »
thanks for the help. I was running 10w-30, it was 70-80 tonight when running, I still dont like it that high, my sb challener runs about 60 at the max, but as long as I don't blow a filter, it sounds good and no problems yet
« Reply #10 on: March 25, 2009 - 02:54:19 AM »
I do believe it can wash the coating of the bearings
« Reply #11 on: March 25, 2009 - 03:03:19 AM »
over 6000 miles I have seen no isues with my 440 running the same pressures , Milodon has an adjustable regulator to decrease the pressure if you are that concerned , I wouldn`t pin the throttle until it has heat in it but really At 7000 RPM you need 70 PSI so you are in the right range
 personally I would leave it alone
« Reply #12 on: March 25, 2009 - 05:00:18 PM »
THANKS FOR THE HELP :cooldancing: :cooldancing: :cooldancing:
« Reply #13 on: March 25, 2009 - 05:13:46 PM »
Don't use a Fram filter.I don't know about Mopars but on a chevy they are known to come apart inside and give you next to no oil pressure.  I don't know how many times at the track ( I'm a tech inspector at my local oval track) I have walked up to people with long faces saying the motor is hurt cause it has no oil pressure. I look down and if it's a fram filter I get them to replace it with a WIX at the track and then 99% of the time that was the problem!!  I've had good luck with WIX
Just my  :2cents:
« Reply #14 on: March 25, 2009 - 06:57:52 PM »
Wix / Napa gold series are the only filter I use anymore
