Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
2000 Dodge Dakota electrical question
« previous
next »
Print
Pages: [
1
Author
Topic: 2000 Dodge Dakota electrical question (Read 1068 times)
72hemi
Resident
MEMBER SINCE JANUARY 2006
on:
March 24, 2009 - 10:34:55 AM »
My buddies dakota has this funny thing going on with the left blinker. more often then not when I turn on the left blinker in the truck it blinks really fast like when a bulb is out. however sometimes it does blink normally and neither of the bulbs are out. Any ideas?
Logged
1996 Dodge Viper GTS Coupe
Chryco Psycho
Administrator
C-C.com Guru
Re: 2000 Dodge Dakota electrical question
Reply #1 on:
March 24, 2009 - 02:30:00 PM »
are you postive when it blinks fast that all the lights are working , I would look for an intermittent connection in the wire
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #2 on:
March 24, 2009 - 06:53:09 PM »
Blinking fast is how it tells you a light is out. Check out each bulb and see if there might be corrosion in the socket. It's a reach, but my best guess for now.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
72hemi
Resident
Reply #3 on:
March 24, 2009 - 07:32:57 PM »
Positive its not a bad bulb. The connections at the bulbs is fine. Where else could the problem be?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
March 24, 2009 - 09:03:55 PM »
turn signal switch possibly you could test that at the plug at the bottom of the column
Logged
72hemi
Resident
Reply #5 on:
March 25, 2009 - 01:12:02 AM »
I'll give that a shot. Thanks.
Logged
moprr
Jr. Member
Reply #6 on:
March 25, 2009 - 04:31:09 PM »
The same thing happened on my durango but the indicator on the dash was also very dim. The wiring for the trailer hitch was pinched to the frame sorting out some times but not enough to blow a fuse? I would check all the wiring carefully.
Logged
ntstlgl1970
Resident
T a c o c a t
Reply #7 on:
March 25, 2009 - 05:23:27 PM »
Here are some diagrams
Logged
72hemi
Resident
Reply #8 on:
March 25, 2009 - 05:30:01 PM »
Thanks. i'll check the harness as well.
Logged
dutch
Sr. Resident
Reply #9 on:
March 25, 2009 - 05:31:45 PM »
I would still replace the bulbs one by one ( or just replace them all...) I had the same problem once and I too was 100% sure it wasn`t one of the bulbs. It was one after all...
Logged
*** Bart ***
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
