A/C Vacuum hose and Heater Valve Cable ????
Author Topic: A/C Vacuum hose and Heater Valve Cable ????  (Read 879 times)
Offline jmartin99
« on: March 24, 2009 - 01:25:04 PM »
On a '72 Challenger, where do the A/C vacuum line that connects to the engine and the cable that controls the water valve go thru the firewall?  Is it thru the hole just below the heater box?  Is there a grommet that goes in and then the hose and cable fit thru it? :dunno:
Thanks!
Jeff
« Last Edit: March 24, 2009 - 01:53:37 PM by jmartin99 »
Offline jmartin99
Re: A/C Vacuum hose and Heater Valve Cable ????
« Reply #1 on: May 06, 2009 - 03:27:04 PM »
Anyone????   :1zhelp:
I am hopefully installing the heater-A/C box this weekend and need to know where the vacuum line and water control cable go!   :swear:
Thanks!
Jeff
Offline r15303
« Reply #2 on: May 06, 2009 - 04:15:46 PM »
On a 71 Cuda the vac line passes thru the firewall under the heater box (throught a gromet) and connects to the same fitting as the power brake vac line.  The control cable exits trrough the fire wall next to the brake booster, runs accross above the wiper motor and voltage reg. makes a 90 degree turn toward the front and connects to the water valve.  It is held by a clip on top of the valve.  Best I can remember.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #3 on: May 06, 2009 - 07:10:36 PM »
 :iagree: I think...  :eek4:
 :bigsmile:
Go Fast & Have Fun...
