Author Topic: Orange or Chrome ecu box?  (Read 2443 times)
Offline shadango
« on: March 25, 2009 - 05:24:15 AM »
I have a 74 318 in my car.....need to get the ecu box.....I am not sure how the motor is built.....but I was told it was rebuilt to factory specs 5  years ago.
Should I get the orange or chrome box, as I see the chrome has "a hotter spark".......its only a $20 difference but if it is wasted $$$ why spend it....
Thanks guys.
Re: Orange or Chrome ecu box?
« Reply #1 on: March 25, 2009 - 07:53:20 AM »
Get the chrome box. The orange ones are cheaply made now.   :22yikes:
« Reply #2 on: March 25, 2009 - 07:55:18 AM »
 :popcorn: I'll need to know this one at some point too?
« Reply #3 on: March 25, 2009 - 09:42:26 AM »
 :bigsmile:  I run a 72 340 cuda box on mine. Right over the counter. It is for 1972 sb hp only.  Runs my 440-6 easy enough with no issues at all. Spins my engine to 6700 but goes higher and my plugs stay clean.  So a 74 318 would have no trouble with that box.   Or a chrome one if you need the look and the talk on the walk :2thumbs:
« Reply #4 on: March 25, 2009 - 11:08:09 AM »
spend a few extra $$ & get the Chrome , if you are buying the kit Mancinis has the Chrome up grade for minimal cost
Offline shadango
« Reply #5 on: March 25, 2009 - 09:19:14 PM »
Well, I stopped at NAPA after work and was surprised to see that they wanted $51 for a stock ecu box! They do carry acheaper one for $38 I think it was.....
I can get the chrome for $58 and the orange for $38 online!
So not a whole lot of difference.
If having the chrome one with hotter spark isnt a BAD thing then maybe I will just go that route anyways. ??
« Reply #6 on: March 25, 2009 - 09:33:51 PM »
my answer hasn`t changed ... get the Chrome one
Offline shadango
« Reply #7 on: March 25, 2009 - 09:56:30 PM »
What ballast do you use for the chrome box?
The ballasts I see on the mopar parts sites say "for orange box", "mechanical advance"  or "resto 4 prong"....nothing about the chrome one?
« Reply #8 on: March 26, 2009 - 12:35:02 AM »
the ballast only protects the coil , I use a low Ohm 2 pin resister , the ECU has moved the resister inside the box so you never need  to use the 4 pin
Offline 71chally416
    • The Streetwalker
« Reply #9 on: March 26, 2009 - 12:50:19 AM »
Runs my 440-6 easy enough with no issues at all. Spins my engine to 6700 but goes higher...
   :22yikes:
Offline cudaneil
  • Mopar or Nocar ?
« Reply #10 on: March 26, 2009 - 08:36:25 AM »
 I just got an FBO upgrade ignition kit...........plug and go !     Quality !!!     (MOPAR A688)
         www.4secondsflat.com                 check em out                          :bigsmile:
« Last Edit: March 26, 2009 - 08:39:03 AM by cudaneil »
just one more job to do..................  (O----{|||}----O)
Offline Justins72
« Reply #11 on: March 26, 2009 - 11:49:54 PM »
not to hi jack the thread but where do you get the low ohm 2 pin resitor? I have the chrome box and am using the 4 pin that the car already had. thanks
« Reply #12 on: March 27, 2009 - 01:16:39 AM »
I use the Napa / Standard Parts ones
Offline shadango
« Reply #13 on: March 27, 2009 - 05:39:28 PM »
I just picked up a "duralast" at autozone for $24 and tax....life time warranty.....so not a bad deal I guess...
I just needed something to put into the car to get it running....once it is running will look to upgrade.....
Thanks all for the advice!
Offline 71chally416
    • The Streetwalker
« Reply #14 on: March 27, 2009 - 06:57:15 PM »
I honestly don't know what could really be that much different in any of those little ECU boxes you buy. Whatever's inside has to all fit inside something the size of a cigarette pack. Any of them will work OK on a mild street motor. I had the orange one on my Chally when I bought it and it worked fine, but when I put the big motor in the idle definately improved with the Digital 6 MSD and I needed a rev limiter. A mostly stock motor has one already built in with the stock heads  :lol:
