Author Topic: LCA pivot shaft removal  (Read 639 times)
Offline txchallenger
« on: March 25, 2009 - 10:40:50 PM »
Whats the best/easiest way to remove the pivot shaft from the lower control arm on a 72 challenger to replace the bushings ?   :clueless:
Thanks
Offline LAA66
Re: LCA pivot shaft removal
« Reply #1 on: March 25, 2009 - 11:06:50 PM »
 Heat the rubber center area with a torch for about 10 minutes. Then use a large punch from the hex end to push the shaft out. The metal bushing shells then need to be removed from the LCA and the pivot shaft. FFI said an air chistle works well but never tried that.
 I cheated and went with a poly replacement. :misbehaving:
« Reply #2 on: March 26, 2009 - 12:39:07 AM »
I use a ball joint fork & pry the pin out after heating it up
« Reply #3 on: March 26, 2009 - 07:14:31 AM »
Thanks guys
