Author Topic: To Heli Coil or not- that is the question  (Read 800 times)
Offline CUDA JAS
  • vroooooom!
« on: March 27, 2009 - 10:44:07 AM »
I have a striped header bolt in on my 360 (the wet one of course).
I know I can heli coil it, but if I am going to drill it out anyway, can I not drill it and tap it for a larger bolt/stud or am I missing something).
I have both the heli coil to bring it back to origional size (5/16 i think), and a larger stud (3/8).  Other than haveing a different size nut on one stud, is there any reason not to do this?
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline hemiken
Re: To Heli Coil or not- that is the question
« Reply #1 on: March 27, 2009 - 10:50:37 AM »
The only problem i see is if your  headers are large and you will not be able to get a spanner on the nut if it is too large  :2thumbs: because of the pipe size of course.
« Reply #2 on: March 27, 2009 - 12:08:22 PM »
going to 3/8 is ok but not I deal as it will get close to the header but helicoiling it is worse , now you have 2 sets of threads to seal & this rarely works , what you need to use is a timesert , itis a metal sleeve that will not leak once installed , going to 3/8" may still be the best option though
Offline moper
« Reply #3 on: March 27, 2009 - 12:28:13 PM »
Offline Bluemonster71RT
« Reply #4 on: March 27, 2009 - 12:39:07 PM »
I had put a heli coil in my 383 and it always leaked both coolant and did not seal the header as good so  :iagree:
1971 Challenger RT 383 4spd
wagesofsin
« Reply #5 on: March 28, 2009 - 09:06:00 PM »
timesert is the way to go. maintains the original thread size , and material integrity.
heli-coils are junk , not saying they wont/dont work.....
this may start a humbug, but i know it to be true. :bigsmile:
« Last Edit: March 28, 2009 - 09:08:52 PM by wagesofsin »
Offline heminut
« Reply #6 on: March 28, 2009 - 11:33:43 PM »
I've used heli-coils for years in aluminum and they have always worked great. Most of the time it has been in Harleys, which are air cooled so there's never been a coolant leakage problem. I agree with CP that it would be next to impossible to keep a heli-coil from leaking coolant.
1970 5.7 Hemi Cuda
Offline Changin Gears
« Reply #7 on: March 29, 2009 - 08:12:27 AM »
I think MR. Gasket sells some header studs that are 3/8" into the block and 5/16" for the nut.
Offline moper
« Reply #8 on: March 29, 2009 - 10:43:52 AM »
I've always just gone to the next size up on those holes. But that only works once per hole...lol.
