Author Topic: Removing factory quarters  (Read 1944 times)
Offline DmanSRT69
  • Diggin' holes is fun
Re: Removing factory quarters
« Reply #15 on: April 06, 2009 - 10:15:38 PM »
That's a great tip.
Brad :feedback:When I did mine I drilled through both panels with a regular bit (small hole then larger hole).  When I installed the new quarter I did not drill any holes in the flange and came in from the inside of the panel to fill.  This leaves a nice looking, almost spot weld look, without having to grind.
Offline rallye73
  • Model cars for the big boys!!
« Reply #16 on: April 07, 2009 - 12:20:06 AM »
I used the center punch and Blair cutters on my car and it worked great.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
Offline Todd DesMarais
« Reply #17 on: April 08, 2009 - 09:03:30 PM »
Brad, I personally use the spring tip style not the pilot style. I use a center punch and set the spring tension pretty high. This will keep the tip from wandering out of the punched hole but causes a little quicker arm/hand fatigue. I only "cut" through one side for things like floor pans, trunk pans, wheel wells, skins etc. as you don't want to damage the structural base metal that you need to attach to. on other parts i might go through both if you can access the base material from behind to weld through as mentioned above, but typically i just go through one. Just remember, if you can't fill the hole, it will cause a weak spot and a place for dirt/moisture to gather.
  Todd
74 'Cuda                       "There's a fine line
66 Belvedere II               between a hobby
66 Satellite                    and a mental illness"
05 Ram 3500 CTD
Offline usraptr
« Reply #18 on: April 09, 2009 - 10:03:45 PM »
Thanks everybody for the sugggestions :2thumbs:  They have been very helpful.  I have the passenger quarter off and will start working on the drivers side shortly.  Is this a great forum or what.   :bananasmi
(Edited 8-1-17)
