Front valance fit ok, easy to correct mismatch with movement of lower front fenders. Better not bump into anything bigger than a gerbil cause the valance would crumple:)
The R/T hood length was good, curve up at the rear by the windshield matched my 1974 original fenders. The biggest issue is the arc front to back of left vs right sides; they are not the same, close but not the same. So hood needs to be "bent" along drivers side edge with the center of that length higher. Will let you know if bigger issues arise.
On the bright side hood was stiff enough to not feel like it was going to buckle against the spring force of AMD hood hinges.
Will have a report in next 1-2 weeks on RH Goodmark rear quarter, LH AMD rear quarter, and AMD roof skin.
