Author Topic: Clutch pictures  (Read 4136 times)
kudakidd
Re: Clutch pictures
« Reply #15 on: April 05, 2009 - 07:38:12 PM »
Beat this!
Offline Husker Cuda
Re: Clutch pictures
« Reply #16 on: April 05, 2009 - 08:33:13 PM »
Ouch!  that had to make a lot of noise when it broke!  What engine are you running?
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
kudakidd
Re: Clutch pictures
« Reply #17 on: April 05, 2009 - 09:35:20 PM »
A 440 4 speed w/ a Dana (3.54's). It happens when you put slicks on a 4,000 lb. car! Oh yeah, it was my old Charger, not my #matching Kuda!
Re: Clutch pictures
« Reply #18 on: April 06, 2009 - 01:12:36 AM »
Looks like you beat it ........... to death  :2thumbs:
Offline 72 cuda
Re: Clutch pictures
« Reply #19 on: April 06, 2009 - 06:50:13 AM »
Question ? I have seen in the past, the flywheel and pressure plate to become hardend from the heat. from the tint of the plates is this part of the culprit?
whith a scratch test(if you can't scratch it with a pocket knife it may be to hard for the clutch to grab).
Poor boy special repair,aneal it gently whith torch.
chryco will this work.
mark
Re: Clutch pictures
« Reply #20 on: April 06, 2009 - 10:56:09 AM »
Not sure , I have not tried it  :dunno:
Offline ShelbyDogg
Re: Clutch pictures
« Reply #21 on: April 06, 2009 - 02:11:42 PM »
I always hardened the back brakes on my 3/4 Suburban when I used to tow my race car to the track. They were so hard that even when not towing, they would chatter till replaced. The heat would make them so dry that I don't think anything could have fixed them. Same type of material.
If you have a clutch out, why not replace it.
Offline Husker Cuda
Re: Clutch pictures
« Reply #22 on: April 06, 2009 - 08:49:18 PM »
Here is some pics of the new SPEC clutch.  Also the write up on the web site for the 3+ system.  Looks like a great clutch, only problem is they sent me the 11"  :stomp:
My 130 tooth flywheel is only good for a 10-1/2 or 10.95".
SPEC 3+
Types of Driving:
Street, Drag, Pulling, Autocross
The flagship stage for a high powered street or race car that requires a manageable and friendly engagement, the stage 3+ features a carbon semi-metallic full faced material that offers unparalleled life, friction co-efficient and drivability characteristics in one single package. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Great for street, drag, drift, autocross, road racing, pulling, rallye and drift.
High clamp pressure plate
Carbon semi-metallic friction material
High torque sprung hub and disc assembly
Bearing and tool kit
Offline ShelbyDogg
Re: Clutch pictures
« Reply #23 on: April 06, 2009 - 08:55:53 PM »
You'll be sorry that you got that diaphram pressure plate. You have to pull your over-center spring off and it will feel spongy. Plus, those clutches are known for sticking to the floor while speed shifting.  Good Luck.
Re: Clutch pictures
« Reply #24 on: April 07, 2009 - 12:52:22 AM »
  :iagree: Diaphragms were not meant for musclecars ... luckily you have an out they sent the wrong clutch anyway
Offline ShelbyDogg
Re: Clutch pictures
« Reply #25 on: April 07, 2009 - 08:05:10 AM »
Those clutches are good for Chevys or for your wife's mopar, that complains about a clutch that "is too hard to push in"  Or sissyies (sp?)
Offline moper
Re: Clutch pictures
« Reply #26 on: April 07, 2009 - 11:44:40 AM »
Never had issues with sticking or slipping. I have ripped the centers out of the disks with Centerforce. but no issues like were mentioned. Spec makes a very nice clutch. I installed a few in the C style Corvettes with very good results. You may not need the overcenter spring removed either. My knees like Mom's type of clutch  :bigsmile:, and the ones I've installed (cars, trucks, various makes) mine never slipped. Another thought is to be careful breaking it in. Go gently and try not to slip it for the first hundred miles of local street driving.
Re: Clutch pictures
« Reply #27 on: April 07, 2009 - 01:00:22 PM »
I have had a Cforce not last a weekend , I have had the clutch pedal stay on the floor with high RPM shifts , rev limiters are a good thing , all diaphragms realease weird , they come up with light pressure & just as they clamp the pressure increases making it very difficult to engage them smoothly , I will never install one in my cars
Offline Husker Cuda
Re: Clutch pictures
« Reply #28 on: April 07, 2009 - 06:44:35 PM »
I'm going to go ahead and get the correct SPEC clutch and try it out.  CP you can say "I told you so" if it don't work.  McLeod was going to take 2+ weeks to get one out, may take that long with this mess anyway.  I'm going to be gone after tomorrow anyway, my 10 year old finally talked me into taking her skiing this weekend.   :eek2:  So I may need some of you to come put my clutch in while I'm laying in bed with multiple broken bones.  I'm going to try not to do my Sonny Bono imitation.   :rofl:
« Last Edit: April 08, 2009 - 08:39:23 PM by Husker Cuda »
Re: Clutch pictures
« Reply #29 on: April 07, 2009 - 09:05:12 PM »
I`ll be there
