Please explain the difference, single plane vs. dual plane intake
Author Topic: Please explain the difference, single plane vs. dual plane intake  (Read 891 times)
Offline Glennster
I hate to admit that I don't know the difference, but I don't................
Please explain (maybe pictures?) the difference between the single and dual plane intakes.
THANKS for the education!!!
Re: Please explain the difference, single plane vs. dual plane intake
« Reply #2 on: March 28, 2009 - 09:34:43 PM »
Basically single plane is open plemun feeding all 8 cylinders from all 4 bbls , you can get away with a slightly smaller carb this way
dual plane divides the carb in 1/2 & feeds only 4 cylinders from each side of the carb this theoretically improves low rpm response & drivability , this always requires a bigger carb to supply enough fuel @WOT as you cannot get some of the flow from both side of the carb
Offline Glennster
« Reply #3 on: March 29, 2009 - 07:43:52 AM »
good stuff guy, I think I've got it............
For my application, the dual plane would be the way to go............
Offline Changin Gears
« Reply #4 on: March 29, 2009 - 08:02:16 AM »
Anyone have an idea as to why Chrysler made some 318 2bbl as dual plane and some single plane (other than $$$)?  Surly it wasn’t a high RPM screamer.  You would think it would dual all the way, trying to get the best drivability out of it.
Don't hate me for it, but I have a Chevy 4.3 2bbl in my boat (single plane).  Was looking at replacing it with a 4bbl. The Edelbrock performer is advertised as a dual plane, but it is a single.  The 4.3's firing order is 165432.  It is even fire "bank to bank", it does not need to be dual plane.  Just needs the plenum divider.
Offline Glennster
« Reply #5 on: March 29, 2009 - 12:27:06 PM »
Hate you?
How could anyone hate a guy that pulls a Purple Mopar Dragster with an old Rag Top?!?!??!?!?!?
Thanks for the input>>>>>>>>>>
Offline femtnmax
« Reply #6 on: March 29, 2009 - 09:38:31 PM »
I wonder if it was a hood clearance issue.  Single plane could located the carb a little lower.
Phil
