Author Topic: Epoxy Primer Dry Time?  (Read 8299 times)
Offline AMXguy
« on: March 29, 2009 - 12:34:05 PM »
I shot the roof on my project yesterday with epoxy primer, it was about 60 degrees and I gave it an hour mixed before I shot it. this was mid day and the directions said not to use it below 50 degrees, I figured it would be dry before night and didn't worry much about it, now after a 26 degree night it's still soft enough you can leave a finger print if you push hard.
 Is this ever going to dry? I did lay it on pretty thick but I'm not sure what to expect out of this 2 part stuff.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline dutch
Re: Epoxy Primer Dry Time?
« Reply #1 on: March 29, 2009 - 01:29:31 PM »
are you sure you added enough hardener..?   My guess is it should have been dry way before midnight...  :clueless:
*** Bart ***
Offline AMXguy
« Reply #2 on: March 29, 2009 - 02:05:30 PM »
Yeah, the directions said 50/50 mix.  it's been on the self a couple years, it doesn't go bad does it?
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: March 29, 2009 - 02:21:36 PM »
Paints do have a shelf life but are usually OK for a couple years as long as they don`t freeze.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline AMXguy
« Reply #4 on: March 29, 2009 - 03:51:42 PM »
In this country freezing is a normal temperature, and this has frozen many times, on enamel and laquer I've never had a problem but maybe I'm going to get a learmament.
 It does seem to be drying a little, I tried a spot and it's too late to take it off with thinner and it's too tacky to sand off so I guess I'll wait and see.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: March 29, 2009 - 07:42:10 PM »
I would go over the tech sheets, flash time is usually within 15 minutes at a high temp then cured quickly, other than that,
what material did you use? most of the epoxy primers i have use and what we use at the shop you have to use a reducer and a hardner, then the hardner has different types based on your temp being sprayed.
 :dunno:
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline wally426ci
    • maryland mopars
« Reply #6 on: March 29, 2009 - 07:43:40 PM »
Dude, wpoxy really sucks to block with. I used it on my dads Cuda and even after a week it was gumming up the sandpaper.  :villagers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline AMXguy
« Reply #7 on: March 29, 2009 - 08:01:26 PM »
This is Nasson Ful Poxy, it says you can thin it a little with laquer thinner if needed but I didn't.
 I'm thinking I wish I'd have just stayed with my old standard primer.  it's pretty much dry where it's thin but where I heaped it on it will still make a finger print after 24 hours. I can tell it's never going to be a good primer to block even if it does dry.  I'm glad this is a long term project or I'd be ticked, well more ticked.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: March 29, 2009 - 08:08:59 PM »
epoxy primer or Etch primers are primarily used as surface sealers and should be top coated with an additional primer for blocking, epoxy is a bit@h to sand once it cure, but you may not have a normal primer.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline AMXguy
« Reply #9 on: March 29, 2009 - 09:26:34 PM »
That I did not know. I was using it for a high build primer and poured it to it, this might be part of my problem.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #10 on: March 29, 2009 - 09:43:35 PM »
I am in no way a body man. That is the area I always end up getting burned on. But this one thing I have come to know about primer before painting....If the primer doesnt set and cure for a long time and you paint your car to soon, it will shrink up and settle under the paint.
Offline AMXguy
« Reply #11 on: March 29, 2009 - 11:36:23 PM »
I thought about that, I'm just preping for a vinyl top that probably won't go on for a year or so , if it dries all the way I should be ok.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
