Author Topic: J heads on a 76 318?  (Read 769 times)
Offline shadango
« on: March 29, 2009 - 05:19:42 PM »
Well, a neighbor into E bodies came up and was checking out my project car ...72 Barracuda.
I was told it had a 74 318 in it.....Well, my neighbor ID'd the heads as "J" heads  (He pointed out the "J" on them) and said he thought I might actually have a 360......so , now that he got my curiosity going I crawled under and checked out the casting numbers.
On the drivers side, ---   4006730-318-15
On the right side ----     D        N<----       4  -  28   - 76
So its a 76 block, 318.....with J heads.
I have already installed an ECU for a 72-74  318 and a new 72 wiring harness.
SO, the questions are endless now.....but to start
----  Will the 72-74 ECU I have now work OK?
----  Will the J heads mean anything in my application?
----  Tranny wise, can I still use a 727 or 904 from a 72-74 Barracuda?
I looked up the ECU for the 76 engine (in a duster) and its a different part number.....
Please tell me this is gonna be ok....
 :banghead:
Offline torredcuda
  • Epping NH joined 11/23/03
Re: J heads on a 76 318?
« Reply #1 on: March 29, 2009 - 06:16:01 PM »
What is the casting number?J heads may be slightly better than newer heads bet really not much difference.Tranny is fine but make sure you have the right balance converter.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline shadango
« Reply #2 on: March 30, 2009 - 01:48:25 PM »
Thats the key, I know....what convertor to go with...
Thing is, aside from tearing the engine down to see whats inside, I am going by what the seller tells me .....
According to him, it was a stcok motor inside and a 74....well I know its a 76 now.....with J heads....so now I am really up in the air as far as what convertor to use.
« Reply #3 on: March 31, 2009 - 03:41:18 AM »
you can use either the 904 or 727 , you want a neutral balanced converter for it , all 318 were neutral balance
The ECU Will work just fine
Offline shadango
« Reply #4 on: April 03, 2009 - 08:33:04 AM »
I heard from the seller that I bought my car from (he owes me a tranny, crossmember and shaft)......He has my tranny, a 727 with a converter....I assume it to be  a stock setup......I think he said it came from a 73.....
Figured I would go with this for now and cross my fingers.....also thinking about taking the tranny (once I get it) somewhere to have it gone over....
« Reply #5 on: April 03, 2009 - 11:50:11 AM »
makes sense to me
