Author Topic: Torsion bars 70 cuda  (Read 991 times)
Offline 4 speed fish
« on: March 29, 2009 - 09:25:58 PM »
I am getting ready to install my motor from the bottom up.The whole front end is installed on the K frame.I need advice on how to install the torsion bars,and what is the best way to adjust them.
                              Thanks
Re: Torsion bars 70 cuda
« Reply #1 on: March 29, 2009 - 09:34:59 PM »
leave either the upper or lower ball joints disconnected so you can swing the lower control arm down grease both sockets & slide the bar in , dont forget the seal on the bar for the rear socket , jack up the lower control arm & connect the ball joint & thread in the adjuster until the adjuster head is approx even with the bottom of the control arm & adjsut as nessisary
« Reply #2 on: March 29, 2009 - 11:51:52 PM »
Thanks alot for the information.I will do it that way.
