Author Topic: self etching primer  (Read 708 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
self etching primer
« on: March 30, 2009 - 12:10:40 PM »
Do you have to give a light sanding when you use this primer, Thanks Also can i paint right over this or do i have to pime again with standard primer, can it be used over painted surfaces that are well sanded etc,.
« Last Edit: March 30, 2009 - 12:18:15 PM by 300 »
Offline elitecustombody
  • Supra collector
Re: self etching primer
« Reply #1 on: March 30, 2009 - 12:50:09 PM »
depending on the surface it's applied over,mainly make sure everything is clean,sanding or scuffing will never hurt prior the application, it's best that a good 2 part primer surfacer applied before paint,but if you're working on small area,you can skip that step, and as always it's a good idea to read tech sheet or directions off the primer container ,usually you have a small window to apply top coat,if you wait certain period of time, you will have to scuff the surface
Stefan B
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: March 30, 2009 - 12:55:31 PM »
 :iagree: After surfacer though I use a good sealer just prior to paint.
1996 Dodge Viper GTS Coupe
