Author Topic: master cylinder need help  (Read 6991 times)
Offline kmyles
Re: master cylinder need help
« Reply #15 on: April 04, 2009 - 10:19:42 PM »
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline LAA66
« Reply #16 on: April 04, 2009 - 11:48:11 PM »
 If you bought a package it should fit and make sense.
 Maybe you're making your own brake lines though so I can mark their destinations from the meter blocks if needed. :)
 As for master cylinder finish, try cleaning it with lacquer thinner then apply a good clear coat. *(outside only)
 The fluid will still remove the finish in time but a least it's clear and won't leave as noticeable scare.  :2cents:
Offline kmyles
« Reply #17 on: April 05, 2009 - 12:12:29 AM »
------->>>>>I can mark their destinations from the meter blocks if needed. :)
Please do and the connections from the master cylinder. Thanks you've been a great help :2thumbs: :2thumbs:
_________
Kevin
