Author Topic: Dash frame and heater  (Read 538 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: April 01, 2009 - 01:10:01 AM »
There was a discussion a while back about putting in the heater core into I think a 73 or 74 Challenger.  I'm near the point of putting the frame/pad into the car and this got me thinking.  Will the heater box go in after the dash frame is installed or does it need to be put in first?  This is an A/C box for clarification if it makes any difference.
Offline jmartin99
Re: Dash frame and heater
« Reply #1 on: April 01, 2009 - 10:20:31 AM »
Pete,
   I asked this same question days ago and got no response.  As far as I can tell, no the heater box will not go under the dash once it is installed.  I have decided I am going to at least partially remove the dash this weekend to get the box in there.  I am putting together a '72 Challenger, by the way.  Good luck!
Jeff
Offline NoMope Greg
« Reply #2 on: April 01, 2009 - 11:38:06 AM »
It should go in after the dash is in - mine came out without pulling the dash out, so I'd assume it could go in reverse - but I think you'll have an easier time if you mount the box first.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #3 on: April 02, 2009 - 10:53:19 AM »
I do not do many A/C cars but to my knowledge the heater has to go in first
