Posi Lube In Rear Diff
Author Topic: Posi Lube In Rear Diff  (Read 2740 times)
Offline daveh
« on: April 01, 2009 - 08:54:31 AM »
Hey guys I have a 3:23 posi in my Challenger that I recently bought. My question is I'm not certain if the previous owner put in the additive for the posi or not. I'm going to put a tube in just in case my question is will it hurt if there was some in there already and I add more? I don't think so but I'm not certain. Thanks
Re: Posi Lube In Rear Diff
« Reply #1 on: April 01, 2009 - 12:15:29 PM »
I would think not, but if you were worried, you could drain it all and redo it all again yourself. That would actually put your mind at ease.  But I never heard a unit failing for putting in a little extra before
Offline Changin Gears
« Reply #2 on: April 01, 2009 - 12:38:24 PM »
If it's not chattering when turning, I would leave it alone.  Either it has the additive, the gear oil used has the additive or the sure grip is worn enough that it doesn't require it.
Offline burnt orange
« Reply #3 on: April 01, 2009 - 07:06:41 PM »
I'd drain it and refill it.
I have been using GM posi fluid and additive, draining and refilling every 5 or 6 years.  Seems to work.
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #4 on: April 01, 2009 - 11:02:04 PM »
I would run it as is unless it starts to chatter on corners.
I can't belive nobody has said this yet but you won't ever find a Chrysler diff with a "posi" in it, only GM's. The correct name is Sure Grip or the common name of limited slip.
2013 Tige' RZR 343hp
Offline 340Challman
  • 70 Challenger B5 A66 4 spd
« Reply #5 on: April 01, 2009 - 11:09:47 PM »
Are you "posi" tive?   :poopoke: :stirpot: :bigsmile:
Don't look back, I might be gaining on you.
        ___               ___
        _______________
(OO (____________R/T_) OO)
 \______________________/
      \______/    \______/
Offline BIGSHCLUNK
« Reply #6 on: April 01, 2009 - 11:18:35 PM »
for  sure!!!  :roflsmiley:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline JS27N0B
« Reply #7 on: April 01, 2009 - 11:53:47 PM »
You guys need to get a grip!   :roflsmiley:
« Reply #8 on: April 02, 2009 - 01:04:28 AM »
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #9 on: April 02, 2009 - 01:54:36 AM »
This topic made me think about my rear end.  My cuda's rear end.
I put a 3rd member unit (3.91 sure-grip) in it back in 1976.  I haven't done anything to it since.
So I guess it might be a good idea to drain and refill it.
What brand and weight of gear lube should I use and how much will I need?  Do I need to add any sure-grip additives?  And how do I drain it?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline BoughtItNew
  • Barracuda
« Reply #10 on: April 02, 2009 - 05:43:30 PM »
For Sure!
Mike Tritle
DeKalb, IL 60115
Original Owner
74 Barracuda
Purchased Sept. 10, 1974
DesPlaines Chrysler Plymouth
DesPlaines, IL
