Author Topic: .  (Read 949 times)
Offline JS29NOB
« on: April 01, 2009 - 08:52:10 PM »
« Last Edit: December 14, 2010 - 10:14:59 PM by JS29NOB »
Offline 73EStroker
Re: How do you test a Sure Grip on the bench???
« Reply #1 on: April 01, 2009 - 11:01:29 PM »
It is difficult to tell from the way you described it but when I owned a 489SG it was quite a bit harder to break away one axle from the other. All I can say from what you say is that your SG works somewhat but may be on the way out. The 489 style is difficult to rebuild but can be done. It has ben described on this site before how to do it. Requires a machinist with some know how.
Barry (Salmon Arm)
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: April 13, 2009 - 04:44:57 PM »
essentially what you are doing copies the factory test that is done in the car. I think yours measures a little low but not too bad. I don't remember what the spec is though.
Offline oldkimmer
« Reply #3 on: April 14, 2009 - 03:03:59 AM »
...........If i am not mistaken there is a tech artical by Steve DeTar over on the Big Block Dart site.............Kim.......... :canada:
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
