Author Topic: Fliptop gas top  (Read 1025 times)
Offline kmyles
Fliptop gas top
« on: April 03, 2009 - 11:34:35 PM »
trying to install my new fliptop gas lid I got from PG Classics and it seems that the ring is very slopy and is not tight up against the body?? Anyone here everhave this problem?? Any solutions?? Also my filler tube mounting holes didn't quite line with the body (new Quater???) but I think I can get around that....maybe....
 :1zhelp: :1zhelp:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Fliptop gas top
« Reply #1 on: April 04, 2009 - 03:40:18 PM »
sounds like the cap area in the new quarter is stamped wrong
Offline Moparal
Re: Fliptop gas top
« Reply #2 on: April 04, 2009 - 03:51:56 PM »
I have seen others posting here about the ring not fitting good on stock quarters to.  Everyone was complaining about the same issue. Do you have yer old fliptop you can try and see if it fits snug.
Offline 422STROKER
  • Member Since 6/3/06
Re: Fliptop gas top
« Reply #3 on: April 04, 2009 - 03:53:47 PM »
How loose is it?
The tabs on the ring can be bent out to snug it up within reason, my repro was the same way. :2cents:
Tom
Tom
Offline 73Chally
Re: Fliptop gas top
« Reply #4 on: April 04, 2009 - 03:59:49 PM »
The indent that the flip top goes into on the repro quarter is angled a bit, whereas the original quarter was a straight-in type of indent.  What we did with mine (PG also) was grind off just a bit of the outside edges of the mounting tabs of the filler itself.  You don't have to take off much material at all, just grind a bit and test fit it.
Offline kmyles
Re: Fliptop gas top
« Reply #5 on: April 04, 2009 - 05:46:28 PM »
Did this
and this
How loose is it?
Tom
It fit like a glove... :2thumbs: Thanks Guys!!
_________
Kevin
Re: Fliptop gas top
« Reply #6 on: April 04, 2009 - 06:57:42 PM »
I got one from them too. Mine was very loose as well, but I figured it out. Look at the inner ring ( on trim ring) notice the tabs that have a bit of a bend ( crease) too them? Well grab a pair of pliers and bend them a little more to take up the slop. I believe that's how they are designed to work. Meaning the corner that you just bent will press against the cap when you screw it down and take up the slack.
Re: Fliptop gas top
« Reply #7 on: April 04, 2009 - 07:00:04 PM »
oops sorry didn't realize you had solved it till I posted! :sleeping:
Offline 422STROKER
Re: Fliptop gas top
« Reply #8 on: April 04, 2009 - 08:02:38 PM »
 :2thumbs:
Tom :clapping:
 :useless:
Tom
Offline RaptorF229
  • A work in Progress
Re: Fliptop gas top
« Reply #9 on: April 04, 2009 - 08:36:51 PM »
I just installed my pg cap a few weeks ago.It fit perfect with no problems
Offline kmyles
Re: Fliptop gas top
« Reply #10 on: April 05, 2009 - 09:44:11 PM »
_________
Kevin
Offline challengermaniac
Re: Fliptop gas top
« Reply #11 on: April 05, 2009 - 10:00:33 PM »
Here's a pic of the fix for future reference, keeping in mind the pictured trim ring is 180 degrees off.
Charlie 70 Challenger
69 Camaro RS
« Last Edit: April 05, 2009 - 10:36:34 PM by challengermaniac »
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline 422STROKER
Re: Fliptop gas top
« Reply #12 on: April 05, 2009 - 11:10:07 PM »
Tom
