Author Topic: hard reverse 2-3 upshift  (Read 974 times)
Offline willard
    • 1970 Challenger R/T
« on: April 04, 2009 - 04:26:59 AM »
I installed TF1 kit recently and everything works ok but one problem remained (it's just more evident now than before transgo installation). Putting car into D is smooth but reverse is very hard/hars, so is upshift to 3rd. Moreover the upshift to 3rd is apporx 1 second delayed but the revs stay at the same level. Just pushing the lever ... bang after 1 second and it's in 3rd. Sometimes it shifts to 3rd smoothly (rarely).
The fluid level is ok, TV cable adjusted properly, linkage adjusted properly. When assemblying, I set both bands at 72 in-lbs and then 2 1/2 turns back.
Should I play with KD band adjustment or it is not related with?
1970 383 R/T SE
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
Re: hard reverse 2-3 upshift
« Reply #1 on: April 04, 2009 - 06:35:08 AM »
Reverse and third gear uses same clutches at the front drum. Problem might be there. Is the oil still clear red?
Offline tactransman
« Reply #2 on: April 04, 2009 - 09:35:45 AM »
First off I would set the intermediate band to 1 1 /2 turns. Did you try adjusting your kickdown a little weaker and see what happens?
Terry-tactransman
Union, Mo.
Offline willard
« Reply #3 on: April 04, 2009 - 09:43:00 AM »
Put new oil, has nearly 100 miles and is still clear red. The old oil had approx 1000 miles and was brownish red. Intermediate = kickdown right? I can set it to 1 1/2 turn unscrewed from 72 in-lbs - I just didn't know I can do that with stock 383 and 1800 stall.
Didnt tryto adjust it tighter/softer but will make some adjustment and check the effect.
1970 383 R/T SE
Offline oldkimmer
« Reply #4 on: April 04, 2009 - 11:03:25 AM »
 :canada:.......set the rear band to 2 turns, then it wont b as harsh into rev......kim...
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
