Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Gasket Source
« previous
next »
Print
Pages: [
1
Author
Topic: Gasket Source (Read 517 times)
TRIPLE-GREEN
Full Member
Gasket Source
on:
April 04, 2009 - 11:29:04 AM »
Ok, I have been workin in a hot rod shop for almost 2 years now and I have been looking for a set of ( i might spell this wrong) neoprean valve cover gaskets for my 318. I just changed the valve covers and one side is leaking like crazy. I have to replace. I don't want to use cork. Anyone know where I can get a set?
THANKS!!
PS other problems to fallow.
Last Edit: April 04, 2009 - 11:50:52 AM by TRIPPLE-GREEN
Logged
quagmire
Full Member
Traction Impaired......
Re: Gasket Source
Reply #1 on:
April 04, 2009 - 01:53:03 PM »
I don't know if they are actually neoprene rubber or not, but the Mopar Performance ones are beefy reusable rubber gaskets with a steel core. I have them and have had my valve covers on and off a couple dozen times. They are still in perfect shape and seal excellent. I think they were under $20 too.
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: Gasket Source
Reply #2 on:
April 04, 2009 - 02:46:36 PM »
If it's leaking that bad the gasket probably is not the problem unless they were over tightened & squished.. What kind of valve cover?
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Chryco Psycho
Administrator
C-C.com Guru
Re: Gasket Source
Reply #3 on:
April 04, 2009 - 07:28:15 PM »
FelPro offers them in 3 types , cork composition & rubber , find someone who sells FelPro , I know Summit does
Last Edit: April 07, 2009 - 11:02:55 AM by Chryco Psycho
Logged
TRIPLE-GREEN
Full Member
Re: Gasket Source
Reply #4 on:
April 07, 2009 - 09:28:43 AM »
I have the cheapy chrome covers. So I know that might be my problem. But the guy I had put them on was a spaz. One side is find but the other started to weep a few weeks ago then got worse this week.
Now here may be a twist. I am using a PCV valve on both sides of this 318. Could that be causing to much back pressure. I ask because when I took off the breather and put on the second PCV the car started to leak oil more. I did it because my vents are stuck open and it was pulling engine funk in to the cabin. But now that I think about it that was when things started to leak more.
Could I just be building up to much back pressure?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Gasket Source
Reply #5 on:
April 07, 2009 - 11:04:19 AM »
you need to have the PCV on one side & the breather on the other & crossflow the engine
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Gasket Source
