Author Topic: A833 shift levers  (Read 636 times)
Offline Purple73Cuda
A833 shift levers
« on: April 05, 2009 - 05:17:24 PM »
I am putting together a 4 speed for my 73 340 Cuda. Is the 3-4 lever the flat lever? And I assume the 1-2 lever is the bent lever. Is that correct?
Also the levers have two holes where the shift rods go into. I am assuming using the top holes will give me a longer throw at the shifter and the lower holes will give me a shorter throw. Is that correct? I want to set the shifter up and adjust it before I put the trans into the car.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline Changin Gears
Re: A833 shift levers
« Reply #1 on: April 05, 2009 - 05:37:09 PM »
Correct, correct and correct.
