Author Topic: A/C Heater Box  (Read 5012 times)
Offline kmyles
A/C Heater Box
« on: April 05, 2009 - 09:52:46 PM »
Well it's another challenge ahead. :pullinghair: I pulled out my heater box today to rebuild it before I install. Looks like the paint shop was a little rammy when they pulled it out :banghead: Any ideas on how to rebuild or do I need to look for the backside of the box?? :clueless: I wonder if i bought a fiberglass repair kit do you think I could repair it  :dunno:.
Thoughts.....Comments
Still  :working:!!!!!!!!!!
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Re: A/C Heater Box
« Reply #1 on: April 06, 2009 - 01:08:00 AM »
I would look for a replacement , but I am sure you could fix it with some time & patience , the bonus is the repair would not be seen
Offline kmyles
Re: A/C Heater Box
« Reply #2 on: April 06, 2009 - 01:35:50 AM »
Any idea where I could get a replacement for a decent price? Any luck getting down to look at the SG?
« Last Edit: April 06, 2009 - 01:43:52 AM by kmyles »
_________
Kevin
Re: A/C Heater Box
« Reply #3 on: April 06, 2009 - 03:15:53 AM »
I have not been down there yet , later this week is likely
Offline troutstreamnm
Re: A/C Heater Box
« Reply #4 on: April 06, 2009 - 10:35:44 PM »
I think YearOne is selling E-body heater boxes these days.
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline kmyles
Re: A/C Heater Box
« Reply #5 on: May 11, 2009 - 12:04:47 PM »
Here is what I did. Hopefully it works out. Shouldn"t be able to see anything once I'm done the resto.  I do have the one question about my heater box. Does anyone know where the one line that I am pointing to hook? It's the one with the white Bubble(Check valve??) on the control side.
 :working:
_________
Kevin
Offline jmartin99
Re: A/C Heater Box
« Reply #6 on: May 11, 2009 - 12:56:18 PM »
That appears to be the vacuum supply line that goes through the firewall and hooks to engine vacuum.
Jeff
Offline kmyles
Re: A/C Heater Box
« Reply #7 on: May 13, 2009 - 01:15:20 PM »
Jeff
Any idea where on the firewall it pokes through??
_________
Kevin
Offline kmyles
Re: A/C Heater Box
« Reply #8 on: May 20, 2009 - 01:44:32 PM »
Does anybody have any pics of there engine bay where the vac line comes throught the firewall??? :feedback:
_________
Kevin
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: A/C Heater Box
« Reply #9 on: May 21, 2009 - 07:54:24 AM »
Hope this helps. Its the rubber plug that is held on by 3 screws below the fan motor.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline kmyles
Re: A/C Heater Box
« Reply #10 on: May 21, 2009 - 01:23:53 PM »
Not quite sure which rubber plug your referring to :clueless:
BTW That engine bay looks sharp :ylsuper: :2thumbs:
_________
Kevin
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: A/C Heater Box
« Reply #11 on: May 21, 2009 - 04:51:54 PM »
Thanks. I highlighted the plug that goes in the firewall
Offline miketyler
    • www.miketyler.net
Re: A/C Heater Box
« Reply #12 on: May 21, 2009 - 05:28:31 PM »
On mine, the pass-thru vacuum line is made into the grommet.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
Re: A/C Heater Box
« Reply #13 on: January 23, 2011 - 07:06:30 PM »
This is a pretty old thread but it's the only one I found about fiberglass repair on the heater box.
I'm working on an AC box and there are some cracks that should be pretty easy to repair but the problem I'm mainly trying to fix is the AC drain. It's one of the small ~1" pipes that comes out of the box. I bought this box a long time ago and it came missing most of the little pipe. What can I use to repair/replace the pipe? How would you recommend the repair be done? I've never done any fiberglass repair. What products would be recommended for the job.
Thanks again.
Offline peterro
    • The Pistonhead
Re: A/C Heater Box
« Reply #14 on: January 23, 2011 - 07:20:12 PM »
Also, is the rubber gasket that is pretty thick that goes between the box and the cowl available? I have the DMT AC box rebuild kit and I didn't see it in there.
