Author Topic: speedometer gear  (Read 24598 times)
Offline shadango
Re: speedometer gear
« Reply #15 on: July 27, 2009 - 12:55:03 PM »
Gotcha! The pics are great!  So there should be a dot on the housing that lines up with one of the segmnets/lines....cool!
Do you think my math looks right?
I should have picked up the gears when I was at Carlise....they were EVERYWHERE! LOL
Just didnt know what one to get.
« Reply #16 on: July 27, 2009 - 03:46:47 PM »
At the risk of hi-jacking...My speedo gear housing has had slightly more than an ooze for years(a few drop per week). Is that O-ring available, or can I get away with using RTV on it as a quick fix?
Offline tactransman
« Reply #17 on: July 27, 2009 - 03:49:05 PM »
Mike ,RTV is fine,just make sure everything is dry when it is applied. :2thumbs:
Terry-tactransman
Union, Mo.
Offline Pale Rider
    • Pale Rider
« Reply #18 on: July 27, 2009 - 04:11:33 PM »
I don't see them on Mancini. What number of teeth do you need,I can look at the shop and see if I have one?
And do you have a 33 in the shop?
Offline Changin Gears
« Reply #19 on: July 27, 2009 - 04:18:47 PM »
Same issue here.....mind if I horn in a bit?
I read 30 when I am doing 35 (verified by gps)....that would be like 13% off!
Is that 2.5% figure correct for any number of teeth ?
Do you figure the percentage using the higher number or lower?
I used the higher number...35mph, and found that 30 mph is 14% lower than 35....divide by 2.5 and I get 5.6.... I need 5 or 6 fewer teeth, right?
I dont know what I have in there right now.....
does it just pull out of the tranny once you pull the speedo cable?
Going 35 but reads 5 mph slow - 5/35 = 14.28% off.  So you need a gear that will spin 14% faster.  A gear with 14% fewer teeth will do that.  As an example, if your current gear has 28 teeth you need a gear with 4 less teeth (28 x .1428 = 4).  But, if your current gear has 42 teeth you need a gear with 6 less teeth (42 x .1428 = 6).
Instead of testing at 35 mph I would test at 60 or 70 for better accuracy.
« Last Edit: July 27, 2009 - 04:28:45 PM by Changin Gears »
« Reply #20 on: July 27, 2009 - 04:21:44 PM »
The dealer may still have the one you are lookin for.  The original part numbers were 2538926 through 2538945 with the last 2 digits being the number of teeth.
« Last Edit: July 27, 2009 - 04:28:20 PM by Changin Gears »
Offline shadango
« Reply #21 on: July 27, 2009 - 04:27:55 PM »
Alright now I am officially cornfused.  LOL
I thought each tooth was worth 2.5%?
Is there a formula somewhere where you dump in tire size, rearend ratio and whatever else and out pops the answer?   :smilielol:
« Reply #22 on: July 27, 2009 - 04:35:42 PM »
2.5% is good if you have a 40 tooth gear (1 tooth/ 40 teeth = 2.5%).
The equation I use for a non-testable vehicle is:
Number of Teeth = 259 * (axle ratio/tire diameter)
The method using the GPS is the best because is also calibrates your speedometer in your vehicle.
Offline shadango
« Reply #23 on: July 27, 2009 - 04:40:03 PM »
gotcha...and just saw the 60 mph hint....will do that soon.
Thanks for the help, and sorry to the OP for hijacking a bit!
Offline tactransman
« Reply #24 on: July 27, 2009 - 06:53:38 PM »
I have a black 32,that is as close as I get.
Terry-tactransman
Union, Mo.
« Reply #25 on: July 27, 2009 - 07:04:02 PM »
For you guys with a console and slapstick, there is a bracket you need to remove to get to the speedo gear out. Nothing major here. Two nuts on the passenger's side of the tranny to take off. The first pic here is from the passenger's side.
shadango, I really think you need to know what gear you have in there before we start guessing. It took me three tries using that method.    :lol:
Offline shadango
« Reply #26 on: July 27, 2009 - 10:35:54 PM »
yeah, no doubt.
I plan on pulling the gear first to see what I have in there.   :2thumbs:
Offline CUDA JAS
  • vroooooom!
« Reply #27 on: July 28, 2009 - 07:35:10 AM »
yeah, no doubt.
Before you pull the gear to see what it is (other than wrong), try the spreadsheet at the link below (there is one for a auto or manual trans).  Plug in the numbers and see what gear you need.  Might save a step for you.
http://www.moparts.org/Tech/tech/pages/speedo.html
74 'cuda 360/727
Just call me a gearhead!
Offline shadango
« Reply #28 on: July 28, 2009 - 07:45:33 AM »
Thats awesome!   Thanks!
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #29 on: July 28, 2009 - 09:29:10 AM »
oe. Pinion number      tooth   current OE. number   Y/O number
2538930    yellow                   30   52068152 - NS1                 FD030
2538931   green                31   52068153 - NS1                 FD031
2538932   black                32   52068154                 FD032
2538933   yellow                33   52068155                 FD033
2538934   green                34   52068156                 FD034
2538935   orange                35   J3212735                              FD035
2538936   red                36   52068158                 FD036
2538937   white                37   52068159                 FD037
2538938   blue                38   52068060                 FD038
2538939   green                39   52068061                 FD039
2538940   orange                40   52068062                 FD040
2538941   red                41   2538941                              FD041
2538942   white                42   2538942                              FD042
2538943   blue                43   2538943                              FD043
Check with your local dealers, these are still available, the RED gear is the expensive ine the rest are about 9 bucks. y/o charges avg 29.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
