Author Topic: I need help :( Rear window regulators  (Read 812 times)
Offline MR291
« on: April 06, 2009 - 07:26:15 PM »
Its been so long that the rear window regulators and all the pieces have been out of the car that I forget how to put them back in.
Does anyone have a schematic as to how everything connects.
Appreciate it.
"8 years and still in the garage"
Offline 4 speed fish
Re: I need help :( Rear window regulators
« Reply #1 on: April 07, 2009 - 02:46:36 PM »
I help my body guy do mine on saturday.First attached the regulators to the body with 3 small bolts.Slide the square roller on it into the channel on the body.Then put the long piece in next.Anchor it in the bottom, then  angle to the left on the pass side one to the right on the driver side until it lines up with the hole.Slide thru the hole from the back side,the put the nut which has the washer attach to it on.Do not tighten these nuts.Do both sides like this and let me know when you are done.
Offline MR291
« Reply #2 on: April 07, 2009 - 04:37:03 PM »
Hi,
Got that done.
Next step please.
Thanks.
« Reply #3 on: April 07, 2009 - 05:25:37 PM »
Put the rear window guide in.It snaps on the rear bottom and it has a hole in the upper part that screws to the body.You can move the bottom to line up to the window.Put the window in now and attach the bottom center part of window to the center slide in the long piece.Spring first then washer then the small shoulder bolt.Let me know when you are done with that.I will go look and see how the next step will go.
Offline MR291
« Reply #4 on: April 07, 2009 - 06:47:02 PM »
I have got that done, but unfortunately broke the white slider.  I use the other side for now.
Whats next.
« Reply #5 on: April 07, 2009 - 07:35:35 PM »
The square black guide attached the window slides into the side of the long piece.The black round one goes the other side .Looking at it from the front it goes,long shoulder bolt 1 piece of the roller that goes thru the other side of the regulator arm the other part of the roller.The groove goes into the long piece the shoulder bolt then screws into the window.
You might need to move the window up or down by hand to line everything up
« Reply #6 on: April 07, 2009 - 07:55:25 PM »
I think I have the white center guide if you need one.I will check.
Offline MR291
« Reply #7 on: April 07, 2009 - 10:31:18 PM »
This has been a great help.  Thanks for your time.
I have the passenger side in and working.  Just a bit of alignment to do.  What made it difficult was that it was a power window assembly which left no room for my hands.  They now have a fair bit of cuts and scrapes.  :)
Now to complete the driver's side I am looking for both the black and white portion of the slider.  The white broke and the black dropped somewhere inside the fender where I can not see it.  So if you have a set to sell (or anyone else out there) I could use it.
Thanks again.
« Reply #8 on: April 08, 2009 - 02:48:30 PM »
Yes,I have them.Send me your address and I will mail them to you.
Offline MR291
« Reply #9 on: April 09, 2009 - 07:13:15 AM »
I have sent a PM.
Thanks.
